[OpenLayers-Users] WKT output of constructed Geometry
Christopher Schmidt
crschmidt at metacarta.com
Sun Mar 15 00:27:07 EDT 2009
On Sat, Mar 14, 2009 at 08:52:52PM -0600, John Cartwright wrote:
> Hello All,
> I'm constructing a geometry w/ a pair of points and then trying to
> output it as a WKT text string. However, the parser is complaining that
> "geometry is undefined" so I'm assuming that I'd doing something wrong
> in the Geometry construction. Can someone please help me here?
> Thanks!
> --john
> var parser = new OpenLayers.Format.WKT({
> 'internalProjection': map.baseLayer.projection,
> 'externalProjection': map.baseLayer.projection
> var geom = new
> OpenLayers.Geometry.Point(parseFloat(coords[0]),parseFloat(coords[1]));
> var str = parser.write(geom, true);
Just call geom.toString(); it has a built in WKT format, and you're not
actually reprojecting at all with using the same things. The reason
you're getting the error is because parser.write() takes a feature, not
a geometry, I assume.
> Users mailing list
> Users at openlayers.org
> http://openlayers.org/mailman/listinfo/users
Christopher Schmidt
MetaCarta
