[OpenLayers-Users] WMSGetFeatureInfo Format
Andreas Hocevar
ahocevar at opengeo.org
Mon Mar 16 07:58:05 EDT 2009
Alexandre,
it seems we don't have a CLA from you or Mapgears yet. Is this
correct? If so, please follow the instructions on
http://trac.openlayers.org/wiki/HowToContribute
Thanks!
Andreas.
On Wed, Mar 4, 2009 at 2:13 PM, Alexandre Dube <adube at mapgears.com> wrote:
> We found out what was not working for us. I've prepared a patch that solved
> the problem.
> Could anyone confirm that there is a bug in the original version, please ?
> Kind regards,
> Alexandre
> Alexandre Dube wrote:
>> Hi users,
>> I'm having a hard time using the WMSGetFeatureInfo format.
>> Instead of explaining, below's snippet (1). Because I currently can't
>> have a response from my server since I have problems with HTTPS and proxy, I
>> load a xml (see attached) instead ( it's a msGMLOutput XML from MapServer ).
>> I get an empty features array. Any clue what I'm doing wrong ?
>> (1) /*---------snippet---------*/
>> showResult: function(response){
>> var oFeatures;
>> var oFormat = new OpenLayers.Format.WMSGetFeatureInfo();
>> if(!response){
>> var xmlDoc=document.implementation.createDocument("","",null);
>> xmlDoc.async="false";
>> xmlDoc.load("response.xml");
>> oFeatures = oFormat.read_msGMLOutput(xmlDoc);
>> } else {
>> oFeatures = oFormat.read_msGMLOutput(response.responseXML ||
>> response.responseText);
>> Users mailing list
>> Users at openlayers.org
>> http://openlayers.org/mailman/listinfo/users
> Alexandre Dubé
> Mapgears
> www.mapgears.com
> Users mailing list
Andreas Hocevar
OpenGeo - http://opengeo.org/
Expert service straight from the developers.
