[OpenLayers-Users] Problem showing OpenLayer controls in a page
with a DOCTYPE
sun761980
sun761980 at hotmail.com
Tue Mar 17 09:52:58 EDT 2009
Hi
I am using Visual Studio 2005 and I am also facing a similar problem.
I just used the sample EXAMPLE1.htm file into a aspx code. When i remove
this DOCTYPE i see the map component with zoomin and zoom out icon. When i
add this, the map component does not appear.
Below is the code
<%@ Page Language="VB" AutoEventWireup="false" CodeFile="Default.aspx.vb"
Inherits="_Default" %>
<!DOCTYPE html PUBLIC "-//W3C//DTD XHTML 1.0 Transitional//EN"
"http://www.w3.org/TR/xhtml1/DTD/xhtml1-transitional.dtd">
<html xmlns="http://www.w3.org/1999/xhtml" >
<head runat="server">
<title>Integrating OpenLayers in .NET</title>
<script src="OpenLayers.js"></script>
<script type="text/javascript">
//alert("Open Layer Method");
// making this a global variable so that it is accessible for
// debugging/inspecting in Firebug
var map = null;
function init(){
map = new OpenLayers.Map('map');
//alert(map.id);
//alert(map.innerText);
var ol_wms = new OpenLayers.Layer.WMS(
"OpenLayers WMS",
"http://labs.metacarta.com/wms/vmap0",
{layers: 'basic'}
var jpl_wms = new OpenLayers.Layer.WMS(
"NASA Global Mosaic",
"http://t1.hypercube.telascience.org/cgi-bin/landsat7",
{layers: "landsat7"}
var dm_wms = new OpenLayers.Layer.WMS(
"DM Solutions Demo",
"http://www2.dmsolutions.ca/cgi-bin/mswms_gmap",
layers: "bathymetry,land_fn,park,drain_fn,drainage," +
"prov_bound,fedlimit,rail,road,popplace",
transparent: "true", format: "image/png"},
minResolution: 0.17578125,
maxResolution: 0.703125
map.addLayers([ol_wms, jpl_wms, dm_wms]);
map.addControl(new OpenLayers.Control.LayerSwitcher());
map.zoomToMaxExtent();
</script>
</head>
<body onload="init()">
<h1 id="title">OpenLayers Example</h1>
<div id="tags"></div>
<p id="shortdesc">
Demonstrate a simple map with an overlay that includes layer
switching controls.
</p>
<div id="map" class="smallmap"></div>
<div id="docs"></div>
</body>
</html>
Regards
Sunny
vsaquicela wrote:
> I don't understand.
> How????
> Ruben Pardo-2 wrote:
>> Hi everybody,
>> i solve the problem, it seems to be a wrong path in the images directory.
>> Thanks a lot .
>> Rubén P.
>> 2007/6/28, Christian López Espínola <penyaskito at gmail.com>:
>>> I can't reproduce the bug with a example.
>>> What browser are you using? Do the problem occurs in other browsers?
>>> I can add that in my application i'm using XHTML Strict, but I think
>>> that using HTML 4 mustn't be a problem.
>>> Cheers from the hot Seville :)
>>> On 6/28/07, Ruben Pardo <correosig at gmail.com> wrote:
>>> > Hi,
>>> > I'm checking my html source generated but it doesn't work. I'm using
>>> > OpenLayers 2.4 API, and still have the same problem. When i remove the
>>> tag
>>> > <!DOCTYPE HTML PUBLIC "-//W3C//DTD HTML 4.01 Transitional//EN" "
>>> > http://www.w3.org/TR/html4/loose.dtd" > it works fine.
>>> > My code :...........
>>> > <html >
>>> > <head>
>>> > <meta content="text/html;charset=ISO-8859-1"
>>> > http-equiv="Content-Type">
>>> > </head>
>>> > <body onload="init();" >
>>> > <style type="text/css">
>>> > #map {
>>> > width: 800px;
>>> > height: 500px;
>>> > border: 1px solid black;
>>> > </style><script src="js/lib/OpenLayers.js"
>>> > type="text/javascript"></script> <script
>>> > type="text/javascript" >
>>> > var map,layer;
>>> > function init(){
>>> > map = new OpenLayers.Map('map', { controls: [],tileSize:
>>> new
>>> > OpenLayers.Size(500,500) });
>>> > layer = new OpenLayers.Layer.MapServer( "OpenLayers WMS","
>>> http://192.168.212.20:84/cgi-bin/mapserv.exe?map=/ms4w/apps/prbmosaico/htdocs/prbmosaico.map
>>> ",{layers:
>>> > 'PARCELASDE', TRANSPARENT: 'true'},{ maxExtent: new
>>> > OpenLayers.Bounds(186555.49,4136068.22,211516.81,4156763.12),
>>> maxResolution:
>>> > 104} );
>>> > map.addControl(new OpenLayers.Control.PanZoomBar());
>>> > map.addControl(new OpenLayers.Control.MouseToolbar ());
>>> > map.addControl(new OpenLayers.Control.OverviewMap());
>>> > map.addLayer(layer);
>>> > if (!map.getCenter())
>>> > </script>
>>> > <div style="margin:0px" id="map"></div>
>>> > </body>
>>> > 2007/6/28, Christian López Espínola < penyaskito at gmail.com>:
>>> > > Hola Ruben,
>>> > > The doctype mustn't be a problem with OpenLayers. I'm using ASP.NET
>>> > > with OpenLayers and I hadn't any problem.
>>> > > Please check the HTML source generated by your application and if
>>> you
>>> > > can't find the solution, post a piece.
>>> > > Hope this helps
>>> > > > Hi everybody,
>>> > > > I've got a problem showing controls with OpenLayers when i put a
>>> > doctype on
>>> > > > my html page.
>>> > > > I'm integrating OpenLayers in a custom jsf component, that
>>> autogenerate
>>> > the
>>> > > > DOCTYPE.
>>> > > > It shows me the layers, but not the controls over the layers
>>> > (PanZoomBar,
>>> > > > Overview, etc...)
>>> > > > It works fine when i remove the doctype in the generated code.
>>> > > > ¿how can i solve this?
>>> > > > Thanks a lot in advance
>>> > > > My generated code is ...
>>> > > > "http://www.w3.org/TR/html4/loose.dtd" >-->
>>> > > > <html >
>>> > > > <head>
>>> > > > </head><body onload="init();">
>>> > > > #map {
>>> > > > width: 800px;
>>> > > > height: 500px;
>>> > > > var map,layer;
>>> > > > function init(){
>>> [],tileSize:
>>> new
>>> > > > WMS","
>>> > > > ",{layers: 'PARCELASDE', TRANSPARENT: 'true'},{ maxExtent: new
>>> > maxResolution:
>>> > > > 104} );
>>> > > > map.zoomToMaxExtent ();
>>> > > > </script>
>>> > > > <div id="map"></div>
>>> > > > </body>
>>> > > > _______________________________________________
>>> > > > Users mailing list
>>> > > > Users at openlayers.org
>>> > > > http://openlayers.org/mailman/listinfo/users
>>> > > Regards,
>>> Regards,
>> Users mailing list
View this message in context: http://n2.nabble.com/Problem-showing-OpenLayer-controls-in-a-page-with-a-DOCTYPE-tp1827971p2491480.html
