[OpenLayers-Users] storing mouse click during vector drawing
Alexandre Dube
adube at mapgears.com
Thu Mar 19 08:48:37 EDT 2009
If all that matters to you is to have each of your points after
drawing a feature, then you could register events to your DrawFeatures
controls like this :
controls['point'].events.register("featureadded",'' , featureAdded);
function featureAdded(evt){
var feature = evt.feature;
// then you have access to your geometry
var geometry = feature.geometry;
// you could write a function that gets all points of a geometry
object depending on the CLASS_NAME value
Use Firebug to help.
Hope this helps,
Alexandre
wrap map wrote:
> how can i get the coordinates value on drawing of polygon at each
> mouse click , actually i want to store each coordinates i clicked
> during vector drawing.
> currently i use this for vector drawing controls but at time of
> drawing i cannot get the coordinates at each point i clicked during
> drawing.
> controls = {
> point: new OpenLayers.Control.DrawFeature(vectors,
> OpenLayers.Handler.Point),
> line: new OpenLayers.Control.DrawFeature(vectors,
> OpenLayers.Handler.Path),
> polygon: new OpenLayers.Control.DrawFeature(vectors,
> OpenLayers.Handler.Polygon),
> drag: new OpenLayers.Control.DragFeature(vectors),
> select: select,
> regular: new OpenLayers.Control.DrawFeature(vectors,
> OpenLayers.Handler.RegularPolygon,
> { handlerOptions: { sides: 5} }),
> modify: new OpenLayers.Control.ModifyFeature(vectors)
> for (var key in controls) {
> map.addControl(controls[key]);
> and for reading mouse i use :
> map.addControl(new
> OpenLayers.Control.MousePosition({element:document.getElementById("longlats"),
> numdigits:3}));
> if it is in navigation only mode i can read and store mouse click as :
> OpenLayers.Control.Click = OpenLayers.Class(OpenLayers.Control, {
> defaultHandlerOptions: {
> 'single': true,
> 'pixelTolerance': 0 //, // 'stopSingle': false
> initialize: function(options) {
> this.handlerOptions = OpenLayers.Util.extend(
> {}, this.defaultHandlerOptions
> OpenLayers.Control.prototype.initialize.apply(
> this, arguments
> this.handler = new OpenLayers.Handler.Click(
> this, { 'click': this.trigger },
> this.handlerOptions
> trigger: function(e) {
> var lonlat = map.getLonLatFromViewPortPx(e.xy);
> var pos = "Longitude: " + lonlat.lon + " E, <br/>Latitude: " +
> lonlat.lat + "N"; // alert("You clicked near " + lonlat.lat + "
> N, " +lonlat.lon + "
> E");//OpenLayers.Util.getElement("longval").innerHTML = pos;
> document.data1.longval.value = lonlat.lon;
> document.data1.latval.value = lonlat.lat;
> but i don't got idea how can i combine these all to function together
> while drawing vector point, line and polygon
> /nabin,
> Users mailing list
> Users at openlayers.org
> http://openlayers.org/mailman/listinfo/users
Alexandre Dubé
Mapgears
www.mapgears.com
