[OpenLayers-Users] Layers are not being drawn - proxy issue?
Christopher Schmidt crschmidt at metacarta.com
Thu Mar 19 11:22:09 EDT 2009
On Thu, Mar 19, 2009 at 09:00:56AM -0400, J. Brian Adams wrote:
> I am completely new to openlayers (Started Monday!).  I have been
> working through some examples but with my own data.  I have a map with
> a base layer from openstreetmaps and with a gml layer that I created
> with
> 			var munis = new OpenLayers.Layer.GML("Municipalities",
> "Municipals2006.gml");
> 			map.addLayer(munis);
> It shows up as Municipalities in the menu on the right, but nothing
> shows on the map.  The gml file is on the same machine, a mac, and in
> the same directory as the html file.  I had read that this might be a
> proxy problem, but at that I am lost.
> If this is a proxy issue, how do I work around it?
This is not a proxy problem.
Do you have Firebug installed? is an xmlhttprequest being made?
Regards,
Christopher Schmidt
MetaCarta
