[OpenLayers-Users] Problems with maxExtent and blank images
(Mapserver and Mapnik)
Jay Douillard
jay.douillard at ubc.ca
Thu Mar 19 12:36:50 EDT 2009
Martin,
Take a look at the request url that openlayers is sending to mapserver(using firebug). I've had some issues with floating point rounding errors and missing tiles. Try converting your bounds to integers and see if that fixes the problem.
jay
----- Original Message -----
From: "\"tschobber tschöbbi\"" <tschobber at gmx.at>
To: users at openlayers.org
Sent: Thursday, March 19, 2009 4:14:54 AM GMT -08:00 US/Canada Pacific
Subject: [OpenLayers-Users] Problems with maxExtent and blank images (Mapserver and Mapnik)
I have two layers in Openlayers - one is for rendering Mapnik maps and the other for rendering with Mapserver. Both have the same data from a postgis database and I declare maxExtent (in map options) with the following values:
var mapOptions = {maxExtent: new OpenLayers.Bounds(384619.116883103,467965.222077892,505102.701298797,534231.193506524),
maxResolution:1.6,
numZoomLevels:21);
The problem is if maxExtent is declared I can only see the Mapnik generated map but the map generated with Mapserver just stays blank. Otherwise when I remove the maxExtent attribute I'm able to see the Mapserver generated map but not the Mapnik map.
For Mapnik I'm using a xml file but there is just this line at the beginning that could change anything:
"<Map bgcolor="steelblue" srs="+proj=latlong +datum=WGS84">"
Here is the beginning of the Mapserver mapfile:
MAP
NAME "Map Viewer"
STATUS ON
SIZE 2400 1200
EXTENT -180 -90 180 90
SHAPEPATH "data/"
IMAGECOLOR 255 255 255
UNITS DD
OUTPUTFORMAT
NAME png
DRIVER "GD/PNG"
MIMETYPE "image/png"
IMAGEMODE RGB
EXTENSION "png"
END
PROJECTION
"init=epsg:4326"
END
WEB
IMAGEPATH "/tmp/ms_tmp/"
IMAGEURL "/ms_tmp/"
METADATA
"wms_title" "Map Viewer"
"wms_onlineresource" "http://gaia.geo.at/cgi-bin/mapserv?map=/srv/www/cgi-bin/data/wms.map"
"wms_srs" "EPSG:4326"
END
END
LAYER
CONNECTION "user=root password=pg dbname=air host=titan.geo.at"
CONNECTIONTYPE POSTGIS
DATA "the_geom from gd_line_007_3"
METADATA
END
NAME "fluss01"
PROJECTION
"init=epsg:31297"
END
SIZEUNITS PIXELS
STATUS ON
TOLERANCEUNITS PIXELS
TRANSPARENCY 100
TYPE LINE
UNITS METERS
CLASS
NAME "class0"
METADATA
END
STYLE
ANGLE 360
COLOR 107 174 214
WIDTH 1
# SYMBOL 1
END
END
END
Below are the two layers defined in Openlayers script:
var mapserver_agg = new OpenLayers.Layer.WMS("AGG Mapserver","http://gaia.geo.at/cgi-bin/mapserv?map=/srv/www/cgi-bin/data/wms3.map",{map_imagetype:'AGG',layers: ['land_grenzen01','layer_mapany_080305_3ba6226287c1622', 'bezirk_grenzen_01', 'land_grenzen01','staat01','fluss01', 'stadt01'],format: 'image/png'},{isBaseLayer:false},{singleTile: true});
var mapnikwms = new OpenLayers.Layer.WMS("MapnikWMS","http://gaia.geo.at/cgi-bin/mapnikwms.py?",{
layers:['land_grenzen01','staat01','fluss01','bezirk_grenzen01'],
styles:['land_grenzen01','staat01','fluss01','bezirk_grenzen01'],
format:'image/png'});
Hope you can help me!
thanks + regards
Martin
Psssst! Schon vom neuen GMX MultiMessenger gehört? Der kann`s mit allen: http://www.gmx.net/de/go/multimessenger01
Users mailing list
Users at openlayers.org
http://openlayers.org/mailman/listinfo/users
