[OpenLayers-Users] WMSCapabilities
Bart van den Eijnden (OSGIS)
bartvde at osgis.nl
Thu Mar 19 14:32:15 EDT 2009
you need to override the OGC mimetype in the proxy.cgi script to
text/xml for it to work in IE, see:
http://openlayers.org/pipermail/dev/2007-December/002039.html
Best regards,
Bart
James Leveille wrote:
> This time, with an appropriate title (sorry) ...
> Hi all,
> I've been struggling with de WMSCapabilities (as defined here
> http://trac.openlayers.org/ticket/1176
> <https://webmail.consulting-fujitsu.com/exchweb/bin/redir.asp?URL=http://trac.openlayers.org/ticket/1176>).
> Works fine with FF, but not with IE(6).
> The "capFormat.read" seems to be the problem (Object required).
> Maybe related to XML with IE ...
> Is there a workaround ?
> Thanks a lot
> function handleResult ()
> if (oHttpRequest.readyState == 4) // COMPLETED
> if (oHttpRequest.status == 200)
> try
> var xmlFormat = new OpenLayers.Format.XML();
> var xml = xmlFormat.read(oHttpRequest.responseText);
> var cap = capFormat.read(xml);
> oTitle=cap.service.title;
> oLayersDispn=cap.capability.layers;
> catch (err)
> else
> James
> Users mailing list
> Users at openlayers.org
> http://openlayers.org/mailman/listinfo/users
OSGIS, Open Source GIS
bartvde at osgis.nl
http://www.osgis.nl
