[OpenLayers-Users] Layers are not being drawn - proxy issue?
J. Brian Adams
jb_adams at verizon.net
Thu Mar 19 22:12:10 EDT 2009
I fixed the problem. The first was as you mentioned that I am using
Openstreetmaps and I had failed to add the projection to the layer.
Adding the line
projection: new OpenLayers.Projection("EPSG:4326")
fixed the problem that I had with a KML point file. But the GML layer
then disappeared completely. I had created the GML file from a GRASS
vector file in a state plane coordinate system. That appears to have
been the problem. I re-exported the file from GRASS vector to GML but
this time in a vector that was already in a Lat - Long format. It now
loads and displays correctly.
Thanks for your help.
Brian
On Mar 19, 2009, at 11:22 AM, Christopher Schmidt wrote:
>> On Thu, Mar 19, 2009 at 09:00:56AM -0400, J. Brian Adams wrote:
>>> I am completely new to openlayers (Started Monday!). I have been
>>> working through some examples but with my own data. I have a map
>>> with
>>> a base layer from openstreetmaps and with a gml layer that I created
>>> with
>>> var munis = new OpenLayers.Layer.GML("Municipalities",
>>> "Municipals2006.gml");
>>> map.addLayer(munis);
>>> It shows up as Municipalities in the menu on the right, but nothing
>>> shows on the map. The gml file is on the same machine, a mac, and
>>> in
>>> the same directory as the html file. I had read that this might
>>> be a
>>> proxy problem, but at that I am lost.
>>> If this is a proxy issue, how do I work around it?
>> This is not a proxy problem.
>> Do you have Firebug installed? is an xmlhttprequest being made?
>> Regards,
>> Christopher Schmidt
>> MetaCarta
> Oh, you're using OpenStreetMap. did you confirm that your data isn't
> showing up at 0,0 off the coast of Africa? You should add
> {'projection':
> new OpenLayers.Projection("EPSG:4326")}, as a third arg to your
> Layer.GML.
> Christopher Schmidt
> MetaCarta
