[OpenLayers-Users] Zooming to an extend via link outside map viewport
Heidt, Christopher M. CHRISTOPHER.M.HEIDT at saic.com
Mon Mar 23 08:48:16 EDT 2009
Define map globally outside init, and set its value within.
Var map;
Function init()
	map = new OpenLayers.......bla bla bla
Now you can use map anywhere.
As you get more advanced with js you can learn about closures
and design getter functions, but this should work for now.
-----Original Message-----
From: users-bounces at openlayers.org [mailto:users-bounces at openlayers.org] On Behalf Of Max Stephan
Sent: Sunday, March 22, 2009 9:58 AM
To: users at openlayers.org
Subject: [OpenLayers-Users] Zooming to an extend via link outside map viewport
Hey everybody,
I want to place a link outside the map which zooms to a specified extent (something like "javascript: map.zoomToExtent(new OpenLayers.Bounds(1,2,3,4))" as a link in the body). But it´s logically not that easy because I have to get access to the map-variable that is unfortunately in the init-function.
So I tried several things. For example I defined a function named "zoom"
which contains "map.zoomToExtent(1,2,3,4);" in it´s body but that´s not working at all. The only way that worked was to empty the map-div-container via "document.getElementById('map').innerHTML="";" and to run the function init with the new bounds as a parameter afterwards.
Does anyone know a more elegant way than reloading the complete init-function?
Thx in advance
Max Stephan
View this message in context: http://n2.nabble.com/Zooming-to-an-extend-via-link-outside-map-viewport-tp2517040p2517040.html
Users mailing list
Users at openlayers.org
http://openlayers.org/mailman/listinfo/users
