[OpenLayers-Users] Re : Problem with WFS layer
Nicolas Caussin
lacausse at yahoo.com
Wed Mar 25 08:24:31 EDT 2009
Hi Jan,
I already try :
var wfs = new OpenLayers.Layer.WFS(
"ArabianGulf",
"http://localhost:8080/cgi-bin/mapserv.exe?MAP=C:/ms4w/wfs/ArabianGulf.map&",
typename : "ArabianGulf",
projection: new OpenLayers.Projection("EPSG:900913")
But there is no difference.
Nicolas.
----- Message initial ----
De : Jan H. van der Ven <jhvdven at xs4all.nl>
À : users at openlayers.org
Cc : NicolasC <lacausse at yahoo.com>
Envoyé le : mercredi 25 mars 2009, 13 h 08 min 36 s
Objet : Re: [OpenLayers-Users] Problem with WFS layer
You need to tell OpenLayers again what projection your WFS is in.
So add a projection parameter to your wfs layers
Kind regards,
Jan
NicolasC schreef:
> Hi,
> I'm newbie in GIS and Openlayer.
> I try to display a shapefile (EPSG:3439), which is the border of persic gulf, on a google map layer.
> I write a mapfile for Mapserver which works with QGIS but with Openlayers the WFS layer is displayed in North Africa.
> My code :
> var map;
> function init(){
> var options = {
> projection: new OpenLayers.Projection("EPSG:900913"),
> displayProjection: new OpenLayers.Projection("epsg:4326"),
> units: "m",
> maxResolution: 156543.0339,
> maxExtent: new OpenLayers.Bounds(-20037508, -20037508,
> 20037508, 20037508.34)
> map = new OpenLayers.Map('map',options);
> var gmap = new OpenLayers.Layer.Google(
> "Google Streets",
> {'sphericalMercator': true}
> map.addLayer(gmap);
> "ArabianGulf",
> {typename : "ArabianGulf"}
> map.addLayer(wfs);
> map.setCenter(new OpenLayers.LonLat(0, 0), 2);
> map.addControl(new OpenLayers.Control.LayerSwitcher());
> map.addControl(new OpenLayers.Control.MousePosition());
> My Mapfile code :
> MAP
> EXTENT 258846.354000 2651583.260000 1105456.098000 3113342.963000
> IMAGECOLOR 255 255 255
> IMAGETYPE gif
> SIZE 512 512
> STATUS ON
> UNITS METERS
> CONFIG PROJ_LIB "C:\ms4w\Apache\cgi-bin\proj_lib"
> NAME "adma"
> PROJECTION
> "init=epsg:3439"
> END
> WEB
> IMAGEPATH ""
> METADATA
> "wfs_srs" "epsg:3439 EPSG:4326 EPSG:900913"
> "wfs_title" "adma"
> "wfs_onlineresource" "http://localhost:8080/cgi-bin/mapserv.exe?"
> "wfs_version" "1.1.0"
> END
> QUERYFORMAT text/html
> LEGENDFORMAT text/html
> BROWSEFORMAT text/html
> END
> LAYER
> DATA ArabianGulf.shp
> DUMP TRUE
> DEBUG 4
> METADATA
> "wfs_extent" "258846.354000 2651583.260000 1105456.098000 3113342.963000"
> "wfs_onlineressource" "http://localhost:8080/cgi-bin/mapserv.exe?"
> "gml_geometries_type" "polygon"
> "wfs_title" "Arabian Gulf"
> "gml_include_items" "all"
> "gml_geometries" "Geometries"
> END
> NAME ArabianGulf
> OFFSITE 0 0 0
> PROJECTION
> "init=epsg:3439"
> END
> STATUS ON
> TYPE POLYGON
> UNITS METERS
> END
> END
> If you have any suggestions ???
> Regards,
> Nicolas.
> Geen virus gevonden in het binnenkomende-bericht.
> Gecontroleerd door AVG - www.avg.com
> Versie: 8.0.238 / Virusdatabase: 270.11.27/2021 - datum van uitgifte: 03/24/09 16:00:00
Découvrez les styles qui font sensation sur Yahoo! Québec Avatars.
http://cf.avatars.yahoo.com/
