[OpenLayers-Users] GetFeatureInfo
bartvde at osgis.nl
bartvde at osgis.nl
Fri Mar 27 11:21:36 EDT 2009
maybe I am not understanding the question correctly, but the layer has a
params object, in which you can just select one parameter, e.g.:
mylayer.params.TRANSPARENT
gets the value of the TRANSPARENT parameter.
Best regards,
Bart
> I dont think the WMS object has any other method to get at the
> parameters. You can parse the wms string based on '&' and populate a map
> to get the parameters maybe.
> Regards
> Ajay Ravichandran
> I use wms.getFullRequestString to get the url and then show ALL the
> parameters of the WMS layer (in format text). I only want to show one of
> this parameters. How can I select which parameters I want to display?
> thank you
> http://n2.nabble.com/GetFeatureInfo-tp2537760p2544712.html
> Sent from the OpenLayers Users mailing list archive at Nabble.com.
> Users mailing list
> Users at openlayers.org
> http://openlayers.org/mailman/listinfo/users
