[OpenLayers-Users] IE problems with OL + dojo
William Kyngesburye woklist at kyngchaos.com
Sat Mar 28 11:17:51 EDT 2009
On Mar 28, 2009, at 2:54 AM, Eric Lemoine wrote:
> Hi.
> The "missing tiles" syndrom is often due to setCenter executed too
> early, i.e. before the map div has its final dimensions.
I'm calling zoomToMaxExtent at the very end of the initialization
(dojo.addOnLoad for Dojo).  Is this something that is more likely to
affect IE?
> If Ext is still an option for you I'd recommend looking at GeoExt
> (<http://www.geoext.org>), GeoExt includes a map panel making it easy
> to have an OpenLayers map in an Ext panel and avoiding the types of
> issues you're seeing.
The auto-distribution of javascript question was never answered
clearly by the FSF rep - he sidestepped my latest question of whether
an application with both server and client code can be considered
distributed.
I suppose geoext is an option, since my application wouldn't need to
be GPL.  But, I want to stick with Dojo for now, I like it and have
spent a lot of time on it now.  And geoext doesn't look like it's
ready for production use yet.
> Cheers,
> Eric
> 2009/3/26, William Kyngesburye <woklist at kyngchaos.com>:
>> I mostly have OL working with the Dojo js library.  The main key I
>> found was to load OL *after* dojo, or neither would work right.
>> The map displays correctly, and the dojo layout stuff works, in
>> Safari
>> and Firefox, but IE6+ has problems.
>> With a tiled base layer, one or more of the tiles is not rendering in
>> the initial view (max extents), and the bigger the window, the more
>> missing.  If I zoom in, then back out to the max extents, it renders
>> all tiles.
>> Also, when exiting the web page, there is a javascript error.  The
>> best I could debug it, with companion.js, there is an invalid
>> argument
>> error in Map.js line 890 (multi-file OL), or a syntax error on line
>> 891, depending on whether the map page is embedded in another page or
>> not. (OL 2.7).
>> The same OL map using mapfish/ext does not have these problems.
>> I wonder if Dojo is redefining something that OL needs, that only
>> affects IE browsers?  Or Dojo is changing the DOM differently in IE,
>> and in a way OL doesn't like?  My debugging capability is limited on
>> the IE side.  And this whole adventure (first mapfish, then dojo) has
>> been a crash course in javascript, so I'm still learning ;)
>> If anyone cares to look, the non-embedded version:
>> http://www.mappingspecialists.com/maps/windex-full-dev-dojo.php
>> William Kyngesburye <kyngchaos*at*kyngchaos*dot*com>
>> http://www.kyngchaos.com/
>> [Trillian]  What are you supposed to do WITH a maniacally depressed
>> robot?
>> [Marvin]  You think you have problems?  What are you supposed to do
>> if
>> you ARE a maniacally depressed robot?  No, don't try and answer, I'm
>> 50,000 times more intelligent than you and even I don't know the
>> answer...
>> - HitchHiker's Guide to the Galaxy
>> Users mailing list
>> Users at openlayers.org
>> http://openlayers.org/mailman/listinfo/users
> Envoyé avec mon mobile
> Users mailing list
robot?
[Marvin]  You think you have problems?  What are you supposed to do if
answer...
