[OpenLayers-Users] Problems displaying kmz file in OpenLayers
Asle Benoni
asle.benoni at gmail.com
Sat Mar 28 21:28:39 EDT 2009
I changed the URL but still get this response:
*OpenLayers.Protocol.WFS is not a constructor
map.addLayer(new OpenLayers.Layer.Vector("Gravminne", {
strategies: [new OpenLayers.Strategy.BBOX()],
protocol: new OpenLayers.Protocol.WFS({
url: "http://naturkart.no:8080/geoserver/wfs&request=getmap",
typeName: "gravminne",
featurePrefix: "kulturminner_ns"
/asle
2009/3/28 Andreas Hocevar <ahocevar at opengeo.org>
> add &request=getmap to your url.
> Regards,
> andreas.
> On 3/28/09, Asle Benoni <asle.benoni at gmail.com> wrote:
> > Hello,
> > I tried the new WFS code but I still get this response:
> > <?xml version="1.0" encoding="UTF-8" standalone="no"?><!DOCTYPE
> > ServiceExceptionReport SYSTEM "http:
> > //schemas.opengis.net/wms/1.1.1/WMS_exception_1_1_1.dtd">
> > <ServiceExceptionReport version="1.1.1" >
> > <ServiceException code="MissingParameterValue" locator="request">
> > Could not determine geoserver request from http request
> > org.apache.catalina.connector.RequestFacade
> > @10f829
> > </ServiceException></ServiceExceptionReport>
> > I wonder if this WFS call can give me what I want with a KML response. I
> > want to be able to click on the location and a popup with a style for the
> > popup, show a picture, a link etc. fetched from the PostgreSQL table.
> > /asle
> > 2009/3/27 Andreas Hocevar <ahocevar at opengeo.org>
> >> Hi,
> >> On Thu, Mar 26, 2009 at 5:08 PM, Asle Benoni <asle.benoni at gmail.com>
> >> wrote:
> >> > I am really frustrated about not beeing able to display a kmz layer in
> >> > OpenLayers.
> >> > Here is the code:
> >> > map.addLayer(new OpenLayers.Layer.GML("Gravminne", "
> http://naturkart.no:8080/geoserver/wms/kml?layers=kulturminner_ns:gravminne&format=application/vnd.google-earth.kml+XML&transparent=true&srs=EPSG:4326&transparent=true&
> >> > format: OpenLayers.Format.KML,
> >> > formatOptions: {
> >> > extractStyles: true,
> >> > extractAttributes: true,
> >> > transparent:true
> >> The geoserver url you are using here will always return KMZ, which
> >> OpenLayers cannot parse. Instead, you should use the following to
> >> create your layer:
> >> map.addLayer(new OpenLayers.Layer.WFS("Gravminne",
> http://naturkart.no:8080/geoserver/wms?service=WMS&request=GetMap&layers=kulturminner_ns:gravminne&format=kml&srs=EPSG:4326
> >> formatOptions: {
> >> Is there a specific reason why you want to use KML? WFS would give
> >> you the same result, you would only have to use a style map for your
> >> symbology in addition. This is how to add the layer using the new WFS
> >> protocol:
> >> url: "http://naturkart.no:8080/geoserver/wfs",
> >> For the symbology, you can use OpenLayers.Format.SLD to use a sld file
> >> that you already have on your server. Look at examples/SLD.html to see
> >> how to configure this.
> >> And you need OpenLayers.ProxyHost configured with a working proxy url.
> >> If a map image rendered on the server would also do, you could just
> >> use a WMS layer, and don't even need a ProxyHost:
> >> map.addLayer(new OpenLayers.Layer.WMS("Gravminne";
> >> "http://naturkart.no:8080/geoserver/wms?", {
> >> transparent: true,
> >> layers: "kulturminner_ns:gravminne"
> >> > I can see the http request from the proxy so it is fetching correct
> >> > data (I think) but I cannot see any on the map!
> >> > The request looks like this (FireBug). I am not sure if the EPSG is
> >> > correct. I also tried "EPSG:32632" which I set for the map.
> >> With the WFS setup above (first of my code snippets), the data should
> >> be automatically reprojected to the SRS of your map.
> >> > Can anyone point to how to show a KMZ file from GeoServer as I need
> >> > the options for that layer format. I checked the docs but did not get
> >> > wiser.
> >> As already said, OpenLayers can not parse KMZ, only KML. To make
> >> GeoServer output KML, your request would have to be a WMS request and
> >> look like this:
> http://naturkart.no:8080/geoserver/wms/?service=wms&request=GetMap&layers=kulturminner_ns:gravminne&format=application/vnd.google-earth.kml+XML&format=kml&bbox=0,0,180,90&width=500&height=250&srs=EPSG:4326
> >> This is what will get generated with the second of my code snippets
> above.
> >> Regards,
> >> Andreas.
> >> Andreas Hocevar
> >> OpenGeo - http://opengeo.org/
> >> Expert service straight from the developers.
> Sent from my mobile device
> Andreas Hocevar
URL: http://lists.osgeo.org/pipermail/openlayers-users/attachments/20090329/070a7ab5/attachment.html
