[OpenLayers-Users] layers limit
T. Vieira tvieira at xlm.pt
Mon Mar 30 14:38:12 EDT 2009
I have a map with 92 layers.
I have a layer to move a box. I click on it, and when the wfs response arrives, it shows the box highlighted. The problem is that the DragControl of that box isn't reachable, so i can't move it.
When i take 7 of 92 layers of the list that initialize the map it works fine. Any of the 85 layers works fine. One more layer and the box is not reachable.
Any advice?
> Layers get placed in the z-index hierarchy based on their "type".  There
> are spaces for 45 (225 / 5) layers between your first "base layer" and
> your first "overlay".
What type of layers are you talking when you said that are spaces for 45?
We only have 1 Baselayer, and the others are Overlayers.
Am i mistaked?
Thanks in advance,
Tiago Vieira
fwiw it's kind of horrendous that we have these things hardcoded in.
perhaps we ought consider some sort of dynamic z-indexing plan?
e
On 1/30/08, Tim Schaub <tschaub at openplans.org> wrote:
> Hey-
> Mick Jagger wrote:
> > Hi,
> >       Is there a limit to the number of layers that OpenLayers supports?  I have a page with 63 layers and I get errors with Internet Explorer at layer 60, while Firefox and Opera load the page fine, albeit slowly.  Normally there are only a couple layers, but this is an odd case.
> your first "overlay".  After this, things start overlapping (base layers
> over overlays).  Similarly, there is room for 65 "overlay" layers (325 /
> 5) under any "popup" layers.  Finally, you get 50 "popup" layers before
> you start overlapping the controls.
> None of these numbers matches the limit of 60 that you are asking about,
> but the idea is that browsers start to break down before either of these
> thresholds is met.
> There is likely a better way to do things than adding 60ish layers to
> your map at a time.
> Tim
> Users mailing list
> Users at openlayers.org
> http://openlayers.org/mailman/listinfo/users
Users mailing list
View this message in context: http://n2.nabble.com/layers-limit-tp1827312p2558926.html
