[OpenLayers-Users] png images, vector layers, pop-ups, and IE
Eric Lemoine
eric.lemoine at camptocamp.com
Mon Nov 2 04:16:33 EST 2009
On Fri, Oct 30, 2009 at 3:36 PM, Wendell Turner <wendell at enflight.com> wrote:
> On Fri, Oct 30, 2009 at 06:30:45AM +0100, Eric Lemoine wrote:
>> On Thursday, October 29, 2009, Wendell Turner <wendell at enflight.com> wrote:
>> > I can't get pop-ups to appear when using png images on a
>> > vector layer in IE. I have a vector layer with points that
>> > have .png images. The images show properly in both Firefox
>> > and IE. The images have pop-ups enabled.
>> > It works fine in Firefox (pop-ups actually pop up), but in
>> > IE the mouseover turns the cursor into an insert symbol,
>> > similar to 'I'. There is no mouse capability on the symbol
>> > in IE.
>> > Other vector layers with drawn polygons work fine in IE, and
>> > pop-ups occur as normal.
>> > Is there a way to fix this so mouse-enabled pop-ups appear
>> > when using png images in IE?
>> Hi
>> Are you using Control.SelectFeature?
> Yes.
I modified the select-feature-openpopup.html so points with external
graphics can be drawn and selected (see attached patch). The example
works as expected in IE8. Can you modify the example yourself and
reproduce your problem?
Cheers,
Eric Lemoine
Camptocamp France SAS
Savoie Technolac, BP 352
73377 Le Bourget du Lac, Cedex
Tel : 00 33 4 79 44 44 96
Mail : eric.lemoine at camptocamp.com
http://www.camptocamp.com
Type: text/x-patch
Desc: not available
Url : http://lists.osgeo.org/pipermail/openlayers-users/attachments/20091102/f1dbb9ff/select-feature-openpopup.bin
