[OpenLayers-Users] split WMS GetFeatureInfo results
stash
st.sonstiges at web.de
Wed Nov 4 03:06:47 EST 2009
Barend Kobben wrote:
> That's probably more a question to ask the underlying WMS (in your case
> geoserver?) ; Eg. I know that when using Mapserver as a WMS, I would
> change
> the
> &INFO_FORMAT=text/plain
> To
> &INFO_FORMAT=text/html
> And then make sure I have HTML templates that provide only the attributes
> I
> want, layed out and styled like I want...
> Barend Köbben
> International Institute for Geo-Information
> Sciences and Earth Observation (ITC)
> PO Box 6, 7500AA Enschede, The Netherlands
> +31 (0)53 4874253
Hello,
thanks for your answer. In fact, you can build templates in geoserver to
show only the results you want with a getfeatureinfo request. Thanks for the
hint.
But now I have an other problem. Is it possible to define more templates for
one layer?
For example, if the user wants output1 --> template 1 will be used by
geoserver to show the results
if the user wants output2 --> template 2 will be used by
Is this possible?
Regards
stash
View this message in context: http://n2.nabble.com/split-WMS-GetFeatureInfo-results-tp3932043p3943680.html
