[OpenLayers-Users] Highlighting changes in the KML layer
Adrian Popa
adrian_gh.popa at romtelecom.ro
Wed Nov 4 07:46:53 EST 2009
Hello Roald,
I have a question about marking items as new - I guess they are not
marked out of the box, right?
When I do the layer refresh, I just do layer.refresh({force: true}); I'm
not sure what this does internally, but perhaps I can't count on any
attributes I set - to be preserved.
Should I build the variable (hash) where I keep attributes as a
different variable? Or should I keep it in a standalone object?
Also, before I do the refresh - I suspect I need to copy the attributes
of the current objects, issue a layer refresh and then (hoping the
refresh is synchroneous) I should go through the new list and see if I
have new items. If there are, mark them as new (and mark other items as
'old').
Supposing that I do that - what would I need to do to change the aspect
(change color/make bigger) of the "new" items?
I'm afraid this will consume some memory and resources - but I guess I
will see when it's ready...
How does my plan sound like?
Regards,
Adrian
Roald de Wit wrote:
> Hi Adrian,
> Adrian Popa wrote:
>> Thank you for the hint. I suppose I shouldn't expect to see a working
>> demo of what I need :)
>> Do you know if the patches presented in ticket 1259 are already part
>> of openlayers (since the latest version is from january last year?)
> The patches in that ticket are part of OpenLayers since version 2.6,
> so, yes!
> I'm not sure if you use styling coming from the KML file or style it
> all yourself. In your case I think you need to revert to the latter
> case. You will need to do some magic to find out what features are new
> and apply a different style to those items. There are few different
> ways of doing it. One of them might be marking it's 'newness' in an
> attribute of the new feature(s) and use a rule that checks that
> attribute in your style map.
> Regards,
> Roald
>> Thanks,
>> helmi wrote:
>>> The idea from http://trac.openlayers.org/ticket/1259
>>> You could create a selectStyle that could be passed to
>>> Control.SelectFeature quite easily: create a style object, read the
>>> "highlight" styles, create a FidFilter rule for every feature (or
>>> groups of features with the same style), use the according
>>> "highlight" style as symbolizer for the rule, and add the rule to
>>> the style object
>>> helmi03.com <http://helmi03.com>
>>> On Tue, Nov 3, 2009 at 12:59 AM, Adrian Popa
>>> <adrian_gh.popa at romtelecom.ro <mailto:adrian_gh.popa at romtelecom.ro>>
>>> wrote:
>>> Hello everyone,
>>> Sorry if this has already been discussed on the list (didn't really
>>> check), but I would like to know if there is a solution (or at
>>> least a
>>> plan to implement a feature) that �"somehow" highlights
>>> (visually) the
>>> elements that have been loaded �through KML - in contrast to the
>>> elements displayed previously.
>>> I am working at a view that displays alarms on top of the map,
>>> and if
>>> there is a large number of alarms, one more alarm coming every 2
>>> minutes
>>> will not catch the attention of the operator...
>>> I need a mechanism to somehow color/animate symbols loaded
>>> through KML
>>> which were not previously on the map. Symbols which dissapear
>>> between
>>> layer refreshes are not important to me. At the next refresh
>>> cycle, the
>>> highlighted symbols would no longer be highlighted (because they
>>> already
>>> exist on the map).
>>> I have a way to load KMLs periodically, avoiding the cache, but I'm
>>> missing the "highlight" mechanism.
>>> Hope I have presented my request in an understandable manner, and
>>> hope
>>> there is a solution. Maybe a property on the KML layer indicating
>>> if an
>>> item is new or not...
>>> Regards,
>>> Adrian
>>> Users mailing list
>>> Users at openlayers.org <mailto:Users at openlayers.org>
>>> http://openlayers.org/mailman/listinfo/users
Adrian Popa
NOC Division
Network Engineer
Divizia Centrul National de Operare Retea
Departament Transport IP & Metro
Compartiment IP Core & Backbone
Phone: +40 21 400 3099
