[OpenLayers-Users] split WMS GetFeatureInfo results
Roald de Wit
roald.dewit at lisasoft.com
Wed Nov 4 16:10:07 EST 2009
Yes, your proxy script it probably not in the right location. Is it in
the same directory as your example html? If not, change either the
location of your proxy script or the path pointing to it in the example.
You also need to make sure that your web server can run that script.
Good luck,
Roald
stash wrote:
> Hi,
> thanks for the example. But when I try to click on the map I get following
> error:
> Unhandled request return Not Found
> I'm nearly sure this is because of my proxyhost settings. I don't know what
> I'm doing wrong, but my proxyhost doesn't work. (I already downloaded the
> proxy.cgi and copied it on the server, ...)
> Nevertheless thanks for your example. If my proxyhost will work I can try it
> again.
> Regards
> stash
