[OpenLayers-Users] store getfeatureinfo results in variables
stash
st.sonstiges at web.de
Thu Nov 5 05:22:15 EST 2009
Hello,
with the following code, I get a wms getfeatureinfo request and the
information are shown on a window.
map.events.register('click', map, function(e) {
var url = "http://...:8080/geoserver/wms" +
"?REQUEST=GetFeatureInfo" + "&EXCEPTIONS=application/vnd.ogc.se_xml"
+ "&BBOX=" + map.getExtent().toBBOX()
+ "&X=" + e.xy.x
+ "&Y=" + e.xy.y
+ "&INFO_FORMAT=text/html"
+ "&QUERY_LAYERS=MY_LAYER"
+ "&LAYERS=MY_LAYER"
+ "&FEATURE_COUNT=50"
+ "&SRS=EPSG:4326"
+ "&STYLES="
+ "&WIDTH=" + map.size.w
+ "&HEIGHT=" + map.size.h;
window.open(url, "getfeatureinfo",
"location=0,status=0,scrollbars=1,width=800,height=400");
This is working fine so far. But there is one thing, I don't like. I'm
talking about the values I get back. Because every time I get a featureinfo
I get some abbreviations (for example 'ger' instead of 'germany'). This is
because of the values stored in the database.
Because of this I would like to change the values before the window will
show them. Is there any possibility to do this. I watched the code in
firebug but the only thing i saw was the url (getfeatureinfo request).
Can I store the values I get back in variables (to change it manually) and
then show it in a window?
Please help
Regards
stash
View this message in context: http://n2.nabble.com/store-getfeatureinfo-results-in-variables-tp3951318p3951318.html
