[OpenLayers-Users] store getfeatureinfo results in variables
Roald de Wit
roald.dewit at lisasoft.com
Thu Nov 5 06:13:47 EST 2009
Hi stash,
stash wrote:
> Hi Roald,
> thanks for your answer. I know it would be much easier if I used a wfs
> getfeature instead of a wms getfeatureinfo. But the problem is that my
> proxyhost doesn't work (I don't know why and I spent so much time in solving
> this problem), therefore I want to solve my problem with a wms.
> You wrote that it is sometimes possible to get a xml back even with wms.
> What do you mean by this?
Different WMS servers have different output formats for GetFeaturInfo.
IIRC you are using GeoServer. If that is correct, you can specify the
INFO_FORMAT to be 'application/vnd.ogc.gml', then you could pass the
output to the OL GML reader which looks a bit like this:
var gmlReader = new OpenLayers.Format.GML();
var features = gmlReader.read(data); // assuming the result of the
output is in the variable called data
Then you can loop through the features and change the attribute
information any way you like and visualise it any way you want.
Regards, Roald
