[OpenLayers-Users] Dojo and OpenLayers mashup
Christopher Schmidt crschmidt at metacarta.com
Fri Nov 6 09:40:15 EST 2009
On Fri, Nov 06, 2009 at 03:20:32PM +0100, Andre Steenveld wrote:
> My hypothesis is that there is a mix up with some events that are attached
> via dijit._Widget and OpenLayers.Map, but I can't find exactly where or how
> to fix it properly.
> If anyone has any suggestions at all I'd love to hear them. Any other
> feedback or suggestion are welcome as well. For a demo you can point the
> browser of your choice to
> http://bonsai.nmpo.nl/experiments/mapviewer.v2.html
My guess is that you have not configured your max extent and maxresolution
correctly. However, I can't test this, because I can't find where any
of the code that initailizes this map is, or how I can access the
OpenLayers.Map object from the console.
-- Chris
> For a zip file with the source, http://bonsai.nmpo.nl/experiments/viewer.zip.
> If you want to see more layers you can uncomment the layers in the XML file,
> they all work and have the data needed to fill them is supplied in the zip
> as well.
> This message has been sent to the oplayers and dojo mailing lists.
> Best regards, Andre Steenveld
> Users mailing list
> Users at openlayers.org
> http://openlayers.org/mailman/listinfo/users
Christopher Schmidt
MetaCarta
