[OpenLayers-Users] What image types are supported as
icons served through KML?
Adrian Popa
adrian_gh.popa at romtelecom.ro
Tue Nov 10 01:36:30 EST 2009
Thank you,
Then, based on your experience can you recommend a file format for my
markers that would make them look good if I use the scale parameter? I
guess the img parameter uses just raster image types - not vector images...
Right now I use png... If memory serves me well (usually it doesn't)
there is a file format that allows the user to embed different sizes of
a symbol in the same file (e.g. 16x16/32x32/48x48) and the rendering
program can choose the size that fits best... Am I right? Or is this
functionality actually done with multiple files?
Thanks,
Adrian
Christopher Schmidt wrote:
> On Mon, Nov 09, 2009 at 04:26:30PM +0200, Adrian Popa wrote:
>> Hello everyone,
>> I just want to know - what image types are supported to be imported
>> through KML? I would like to convert my icons from PNG to SVG (which
>> looks better when scaled) - but I'm not sure if it will work.
> I don't believe KML, as a format, allows SVG markers... does it?
> In any case, OpenLayers would not be able to render anything other than
> a standard image (something you can put in an <img> tag) as an externalGraphic,
> which is how KML files with icons are parsed.
> -- Chris
>> Is the limitation based only on browser type (and what it can render)?
>> Or are there other limitations I should know about?
>> Thanks,
>> Adrian
>> Users mailing list
>> Users at openlayers.org
>> http://openlayers.org/mailman/listinfo/users
URL: http://lists.osgeo.org/pipermail/openlayers-users/attachments/20091110/c5533730/attachment.html
