[OpenLayers-Users] Vector Layer,
WFS Protocol and BBOX strategy problem
Andreas Hocevar
ahocevar at opengeo.org
Tue Nov 10 07:37:02 EST 2009
do you have proj4js.js included in your html page? See
http://trac.openlayers.org/wiki/Documentation/Dev/proj4js
OpenLayers out of the box can only transform between EPSG:4326 and EPSG:900913.
Regards,
Andreas.
On 11/10/09, Pedro Baracho <pedropbaracho at gmail.com> wrote:
> Thanks for the reply.
> I changed to 1.1.0, but I am still having problems with projections.
> The BBOX filter of the request is being built with weird numbers on it:
> <ogc:BBOX><ogc:PropertyName>GEOLOC</ogc:PropertyName><gml:Envelope
> xmlns:gml="http://www.opengis.net/gml"
> srsName="EPSG:29193"><gml:lowerCorner>-4987936.2379319
> -2307634.0730985</gml:lowerCorner><gml:upperCorner>-4797149.4153663
> -2213769.4023813</gml:upperCorner></gml:Envelope></ogc:BBOX>
> Those numbers don't make any sense in EPSG:29193 (
> http://spatialreference.org/ref/epsg/29193/)
> The bounds should be limited to: 166020.2387, 7087605.5418, 833979.7613,
> 10000000.0000, and I am seeing some negative numbers.
> I also changed the displayProjection on the map to EPSG:29193 and those
> weird numbers are confirmed by OpenLayers.Control.MousePosition.
> My guess is that there is some problem with the reprojection routine from
> 900913 to 29193. I am also guessing this may be because 29193 is limited to
> a region of the globe while 900913 is a world-wide projection. Does it make
> sense? I don't know much about cartography and projections and I didn't dig
> in OpenLayers code yet.
> Do you have any other hint for me?
> On Mon, Nov 9, 2009 at 6:40 PM, Andreas Hocevar <ahocevar at opengeo.org>wrote:
>> Hi,
>> WFS 1.0.0 does not support on-the-fly reprojection. You have to use WFS
>> 1.1.0, which is e.g. supported by GeoServer. And you have to specify the
>> version on the protocol:
>> Pedro Baracho wrote:
>> > var layer = new OpenLayers.Layer.Vector("WFS", {
>> > strategies: [new OpenLayers.Strategy.BBOX(),
>> > saveStrategy],
>> > protocol: new OpenLayers.Protocol.WFS({
>> version: "1.1.0",
>> > url: "http://localhost:8080/geoserver/wfs",
>> > featureType: "Regional",
>> > featureNS: "http://prodabel1062.pbh:8080/avis",
>> > geometryName: "GEOLOC",
>> > srsName: "EPSG:29193"
>> > projection: new OpenLayers.Projection("EPSG:29193")
>> Regards,
>> Andreas.
>> Andreas Hocevar
>> OpenGeo - http://opengeo.org/
>> Expert service straight from the developers.
Andreas Hocevar
