[OpenLayers-Users] Invisible ZoomBox
acangi
aca at ngi.be
Thu Nov 12 03:34:55 EST 2009
Problem finally solved :
1. The NavToolbar not appearing was due to the missing default style.css.
2. To make my own buttons, I prefered using directly ZoomBox and Navigation,
but removing the controls from the map object to switch between both didn't
work. I had to deactivate them instead of removing them.
acangi wrote:
> Hi list,
> I'm trying to use the controls Navigation and ZoomBox separately : using
> my other (non-openlayers) controls, I'd like to switch between Navigation
> and ZoomBox, like it's done here :
> http://openlayers.org/dev/examples/navtoolbar-alwaysZoom.html
> http://openlayers.org/dev/examples/navtoolbar-alwaysZoom.html , but with
> my own switchers.
> The problem is : I can't see the control switchers like on the example (to
> select one or the other), I have to use SHIFT to create a zoombox, and I
> can't see the zoombox I'm drawing.
> I copy/pasted the class CustomNavToolbar from the example, and this is my
> map :
> function createMap(){
> var bounds = new OpenLayers.Bounds(500000, 500000, 810000,
> 800000);
> map = new OpenLayers.Map('map', {
> controls: [new OpenLayers.Control.CustomNavToolbar(),
> //new
> OpenLayers.Control.ZoomBox({alwaysZoom:true}),
> //new OpenLayers.Control.Navigation(),
> new OpenLayers.Control.PanZoomBar()],
> theme: null,
> maxExtent: bounds,
> maxResolution: 1210.9375,
> numZoomLevels: 11,
> projection: PROJECTION,
> units: 'm'
> // Create an invisible and light layer to display before the user
> chooses the baselayer
> // Openlayers always needs one baselayer
> var clearBaseLayer = new OpenLayers.Layer.Image(
> "None",
> "/PrintOnDemand/img/clear.gif",
> bounds,
> new OpenLayers.Size(8, 8),
> {isBaseLayer: true}
> map.addLayer(clearBaseLayer);
> map.baseLayer = clearBaseLayer;
> Also, there are several WMS layers, a vector layer and I'm adding a
> DragFeature(vectorLayer) later on.
> How comes I don't see the switches to choose between Navigation and
> ZoomBox ? The fact I don't see the box I'm drawing makes me think of a
> z-index problem, but linking the panel to a div and changing that div's
> z-index doesn't change anything.
> Any idea ?
> OpenLayers 2.7, Firefox 3.5
View this message in context: http://n2.nabble.com/Invisible-ZoomBox-tp3267845p3991402.html
