[OpenLayers-Users] mergeNewParams not working
David Alda Fernandez de Lezea
dalda at ikt.es
Fri Nov 13 03:34:18 EST 2009
Sure, here it is:
<xsl:stylesheet version="1.0.0" xmlns:xsl="http://www.w3.org/1999/XSL/Transform">
<xsl:output omit-xml-declaration="yes" method="xml"/>
<xsl:param name="objetoPila" select="null"/>
<xsl:template match="/">
<StyledLayerDescriptor version="1.0.0" xsi:schemaLocation="http://www.opengis.net/sld
StyledLayerDescriptor.xsd" xmlns="http://www.opengis.net/sld"
xmlns:ogc="http://www.opengis.net/ogc"
xmlns:xlink="http://www.w3.org/1999/xlink"
xmlns:xsi="http://www.w3.org/2001/XMLSchema-instance">
<NamedLayer>
<Name>RecintosSigpac</Name>
<UserStyle>
<Name>Selección de Recintos</Name>
<Title>Título</Title>
<Abstract>Comentarios</Abstract>
<FeatureTypeStyle>
<Rule>
<ogc:Filter xmlns:gml="http://www.opengis.net/gml">
<ogc:And>
<PropertyIsEqualTo>
<PropertyName>PROVINCIA</PropertyName>
<Literal>1</Literal>
</PropertyIsEqualTo>
<PropertyIsEqualTo>
<PropertyName>MUNICIPIO</PropertyName>
<PropertyIsEqualTo>
<PropertyName>POLIGONO</PropertyName>
<PropertyIsEqualTo>
<PropertyName>PARCELA</PropertyName>
<PropertyIsEqualTo>
<PropertyName>RECINTO</PropertyName>
</ogc:And>
</ogc:Filter>
<PolygonSymbolizer>
<Fill>
<CssParameter name="fill">#FFCC66</CssParameter>
<CssParameter name="fill-opacity">0.5</CssParameter>
</Fill>
<Stroke>
<CssParameter name="stroke">#00FF00</CssParameter>
<CssParameter name="stroke-width">3</CssParameter>
</Stroke>
</PolygonSymbolizer>
</Rule>
</FeatureTypeStyle>
</UserStyle>
</NamedLayer>
</StyledLayerDescriptor>
</xsl:template>
</xsl:stylesheet>
One more question, I have 2 layers, both are taken from my WMS but one is a raster file, that acts as base layer, and the other one is polygon layer. In which of them do I have to apply the new params??. I've tried appliying them in my polygon layer.
Thanks.
Un saludo,
David Alda Fernández de Lezea
Lurralde eta Biodibertsitate Saila / Dpto. de Territorio y Biodiversidad
IKT
Granja Modelo s/n · 01192 · Arkaute (Araba)
Tlfnos.: 945-00-32-95 Fax: 945-00.32.90
email: dalda at ikt.es web: www.ikt.es
-----Mensaje original-----
De: bartvde at osgis.nl [mailto:bartvde at osgis.nl]
Enviado el: viernes, 13 de noviembre de 2009 9:18
Para: David Alda Fernandez de Lezea
CC: users at openlayers.org
Asunto: Re: [OpenLayers-Users] mergeNewParams not working
Can you post the contents of your SLD XML?
Best regards,
Bart
> Hello,
> I want to apply some SLD generated on the fly through SLD_BODY
> parameter using the following code:
> var sld = getSLD("sld1.xsl","pilaXML.xml"); var wms =
> map.getLayersByName("myLayerName")[0];
> wms.mergeNewParams({SLD_BODY: sld});
> but I don't get any result. The image is refreshed in the browser but
> there's no selection at all. I've got a debug file for my WMS server
> and I don't seem to get any error:
> [Fri Nov 13 09:00:18 2009].346000 CGI Request 1 on process 5940
> My SLD contains 2084 characters, it could be that the problem? Or
> maybe I'm doing something wrong. Has anybody any idea of what's happening??
> Thanks.
> Un saludo,
> Biodiversidad
> IKT
> <http://www.ikt.es/>
> Users mailing list
> Users at openlayers.org
> http://openlayers.org/mailman/listinfo/users
