[OpenLayers-Users] Layer not shown
Alexandre Dube adube at mapgears.com
Fri Nov 13 07:59:54 EST 2009
Toni,
Try putting all properties (layers and map) the same :
units: "m",
projection: "EPSG: 4230",
maxExtent:new OpenLayers.Bounds(548757,4138136,716640,4282922)
Here's an similar example :
http://dev4.mapgears.com/bdga/simpleMap.html
Regards,
Alexandre
Toni Ramiro wrote:
> Ok. I've modified the code this way (the red one):
> var opciones = {
> projection:"EPSG:4230",
> units:"dd",
> maxExtent:new OpenLayers.Bounds(-3,37,0,39)
> map = new OpenLayers.Map('map', opciones);
> var sigpac_layer = new OpenLayers.Layer.WMS(
> "PNOA",
> "http://www.idee.es/wms/PNOA/PNOA",
> layers:"pnoa",
> version:"1.1.1",
> format:"image/png"
> map.addLayer(sigpac_layer);
> var mapserver_layer = new OpenLayers.Layer.WMS(
> 'Murcia',
> 'http://localhost/cgi-bin/mapserv.exe',
> map:'D:/Desarrollo/MapServer/datos/ms_murcia_qgis_shp.map',
> layers:'arquetas_otros_planifrega,regulacion_ext_planifrega,conducciones_planifrega,regulacion_int_planifrega,tomas_planifrega,balsas_planifrega,bombeos_planifrega'
> transparent:'true'
> projection:"EPSG:4326",
> units:"m",
> map.addLayer(mapserver_layer);
> map.addControl(new OpenLayers.Control.LayerSwitcher());
> map.addControl(new OpenLayers.Control.MouseToolbar());
> map.addControl(new OpenLayers.Control.MousePosition());
> map.zoomToMaxExtent();
> But I've recived the same result.
> Thanks.
> 2009/11/12 Alexandre Dube <adube at mapgears.com <mailto:adube at mapgears.com>>
>     Hi Toni,
>     Your data projection is in meters, so you must set it in the
>     OpenLayers.Map object as well. By default, it's in degrees [1].
>     Plus, the maxExtent should be in meters too (try using the one
>     from your mapfile).
>     If it's still not working, you can try watching the request built
>     from OpenLayers in Firebug and see the response. There may more
>     more clues there.
>     Best of luck,
>     Alexandre
>     [1]
>     http://dev.openlayers.org/releases/OpenLayers-2.8/doc/apidocs/files/OpenLayers/Map-js.html#OpenLayers.Map.units
>     Toni Ramiro wrote:
>         I'm new to this and I've encountered a problem.
>         I defined the following code to load one layer with OpenLayers
>         var opciones = {
>         "PNOA", "http://www.idee.es/wms/PNOA/PNOA", {
>         layers:"pnoa", version:"1.1.1",
>         format:"image/png"
>         units:"m"
>         'Murcia',
>         layers:'arquetas_otros_planifrega',
>         transparent:'true'
>         units:"m"
>         My MapServer project is as follows:
>         MAP
>         NAME Murcia
>         SIZE 800 600
>         UNITS METERS
>         EXTENT 544061.905938 4135608.106250 720849.906562 4288074.143750
>         CONFIG PROJ_LIB "D:\Desarrollo\MapServer\proj\nad\"
>         PROJECTION
>         'proj=longlat'
>         'ellps=WGS84'
>         'datum=WGS84'
>         'no_defs'
>         END
>         IMAGECOLOR 192 192 192
>         IMAGEQUALITY 95
>         IMAGETYPE png
>         OUTPUTFORMAT
>         NAME png
>         DRIVER 'GD/PNG'
>         MIMETYPE 'image/png'
>         EXTENSION 'png'
>         END
>         LEGEND
>         IMAGECOLOR 255 255 255
>         STATUS ON
>         KEYSIZE 18 12
>         LABEL
>         TYPE BITMAP
>         SIZE MEDIUM
>         COLOR 0 0 89
>         END
>         END
>         WEB
>         IMAGEPATH 'C:/Inetpub/tmp/'
>         IMAGEURL '/tmp/'
>         METADATA
>         'wms_title' 'Murcia'
>         'wms_onlineresource'
>         'http://localhost/cgi-bin/mapserv.exe?map=D:/Desarrollo/MapServer/datos/ms_murcia_qgis_shp.map&
>         <http://localhost/cgi-bin/mapserv.exe?map=D:/Desarrollo/MapServer/datos/ms_murcia_qgis_shp.map&>
>         <http://localhost/cgi-bin/mapserv.exe?map=D:/Desarrollo/MapServer/datos/ms_murcia_qgis_shp.map&>>'
>         'wms_srs' 'EPSG:4326'
>         END
>         END
>         LAYER
>         NAME 'arquetas_otros_planifrega'
>         TYPE POINT
>         DATA
>         'D:\Desarrollo\MapServer\datos\CapasDePrueba\arquetas_otros_planifrega.shp'
>         METADATA
>         'wms_title' 'arquetas_otros_planifrega'
>         END
>         STATUS DEFAULT
>         TRANSPARENCY 100
>         PROJECTION
>         'proj=longlat'
>         'ellps=WGS84'
>         'datum=WGS84'
>         'no_defs'
>         END
>         CLASS
>         NAME 'arquetas_otros_planifrega' STYLE
>         SYMBOL 'CIRCLE' SIZE 2 OUTLINECOLOR 0 0 0
>         COLOR 31 2 3
>         END
>         END
>         END
>         SYMBOL
>         NAME 'CIRCLE'
>         TYPE ellipse
>         FILLED true
>         POINTS
>         1 1
>         END
>         END END
>         The result is that the OpenLayers 'Murcia' layer shows no
>         data, and if left alone in the project only shows a gray
>         background.
>         I've tried the same using QGis WMS client to Mapserver and
>         shows the data.
>         żDo anybody knows how to solve the problem?
>         Thanks a lot.
>         Saludos,
>         Toni Ramiro
>         <anrapas at gmail.com <mailto:anrapas at gmail.com>
>         <mailto:anrapas at gmail.com <mailto:anrapas at gmail.com>>>
>         <aramiro151r at cv.gva.es <mailto:aramiro151r at cv.gva.es>
>         <mailto:aramiro151r at cv.gva.es <mailto:aramiro151r at cv.gva.es>>>
>         _______________________________________________
>         Users mailing list
>         Users at openlayers.org <mailto:Users at openlayers.org>
>         http://openlayers.org/mailman/listinfo/users
>     Alexandre Dubé
>     Mapgears
>     www.mapgears.com <http://www.mapgears.com>
> Saludos,
> Toni Ramiro
> <anrapas at gmail.com <mailto:anrapas at gmail.com>>
> <aramiro151r at cv.gva.es <mailto:aramiro151r at cv.gva.es>>
> Users mailing list
Alexandre Dubé
Mapgears
www.mapgears.com
