[OpenLayers-Users] Add Point to Map
Alexandre Dube adube at mapgears.com
Fri Nov 13 09:04:22 EST 2009
Christopher,
  Look at the following example [1].  It should helps you a lot.  (click
on the small pencil to add a point).
  See also this article [2] about spherical mercator.
Kind regards,
Alexandre
[1] http://openlayers.org/dev/examples/spherical-mercator.html
[2] http://docs.openlayers.org/library/spherical_mercator.html
Jones, Christopher wrote:
> Hi all,
> Im fairly new to OpenLayers and  javascript for that matter as well.
> Having looked extensively through all the various examples and forums
> and blogs, and one or 2 tutorials, I am still struggling to add a
> point to a map (or a vector layer)!  All I want, is to click on a map
> and adda a point.  Heres my code, please feel free to point all the
> errors you want!
> Thanks in advance!
> Chris
> (Sorry if this has been sent twice)
> var myStyles = new OpenLayers.StyleMap({
>     "default": new OpenLayers.Style({
>         fillColor: "#ffcc66",
>         strokeColor: "#ff9933",
>         strokeWidth: 10
> function initialiseMap(){
>         map = new OpenLayers.Map('map');
>         map.addControl(new OpenLayers.Control.LayerSwitcher());
>         var gphy = new OpenLayers.Layer.Google(
>                 "Google Physical",
>                 { type: G_PHYSICAL_MAP }
>         var gmap = new OpenLayers.Layer.Google(
>                 "Google Streets",
>                 {numZoomLevels: 20 }
>         var ghyb = new OpenLayers.Layer.Google(
>                 "Google Hybrid",
>                 { type: G_HYBRID_MAP, numZoomLevels: 20 }
>         var gsat = new OpenLayers.Layer.Google(
>                 "Google Satellite",
>                 { type: G_SATELLITE_MAP, numZoomLevels: 20 }
>                 map.addLayers([gphy, gmap, ghyb, gsat]);
>                 map.setCenter(new OpenLayers.LonLat(-74.0094,
> 40.7048), 5);
>                 map.addControl(new OpenLayers.Control.PanZoomBar());
>                 map.addControl(new OpenLayers.Control.MousePosition());
> function singleClickButton() {
>     document.getElementById("map").childNodes[0].style.cursor =
> "crosshair";
>     map.events.register('click', '', singleClickEvent);
> function singleClickEvent (e) {
>     var lonlat = map.getLonLatFromViewPortPx(e.xy);
>     var lon = lonlat.lon
>     var lat = lonlat.lat
>     var pointLayer = new OpenLayers.Layer.Vector('Points', { styleMap:
> myStyles });
>     map.addLayers([pointLayer]);
>     var bPoint = new OpenLayers.Geometry.Point(lon , lat)
>     newpoint = new OpenLayers.Feature.Vector(bPoint);
>     pointLayer.addFeatures(newpoint);
> IMPORTANT - This email and the information that it contains may be
> confidential, legally privileged and protected by law. Access by the
> intended recipient only is authorised. Any liability (in negligence or
> otherwise) arising from any third party acting, or refraining from
> acting, on any information contained in this email is hereby excluded.
> If you are not the intended recipient, please notify
> AmlinCommunications at amlin.co.uk immediately then delete it and do not
> disclose the contents to any other person, use it for any purpose or
> store or copy the information in any medium.
> Copyright in this email and attachments created by us belong to Amlin
> plc and/or one or more of its subsidiaries (Amlin Group). The author
> also asserts the right to be identified as such and object to any misuse.
> The Amlin Group prohibits and takes steps to prevent its email systems
> from being used to view, store or transmit offensive, obscene or
> discriminatory material. If this message contains inappropriate
> material please report it immediately to AmlinCommunications at amlin.co.uk.
> The Amlin Group records, monitors and may inspect messages that use
> its telecoms systems in order to protect its information, interests
> and reputation. Any message sent by you to or within the Amlin Group
> may therefore be viewed and may be acted upon.
> Of the companies within the Amlin Group, Amlin Underwriting Limited,
> Amlin Underwriting Services Limited, Amlin UK Limited and Amlin Plus
> Limited are authorised and regulated by the Financial Services Authority.
> This email has been sent by a member of staff of one or more of the
> following Amlin Group companies:
> Amlin plc. Registered in England and Wales no. 2854310
> Amlin Underwriting Limited. Registered in England and Wales no. 2323018
> Amlin Underwriting Services Limited. Registered in England and Wales
> no. 422615
> Amlin UK Limited. Registered in England and Wales no. 2739220
> Amlin Plus Limited. Registered in England and Wales no. 4729659
> Registered Offices: St Helen's, 1 Undershaft, London EC3A 8ND, United
> Kingdom
> Amlin plc switchboard: 020 7746 1000
> Web Site: http://www.amlin.com
> Users mailing list
> Users at openlayers.org
> http://openlayers.org/mailman/listinfo/users
Alexandre Dubé
Mapgears
www.mapgears.com
