[OpenLayers-Users] Trying to draw a box on a map,
and get the coordinates back.
J. Cliff Dyer
jcd at sdf.lonestar.org
Fri Nov 13 11:28:11 EST 2009
I'm trying to draw a box on a map, have it persist until another box
gets drawn, and submit the coordinates of the box to a form. I'm doing
this to allow the user to search for objects within a given area.
I'm doing this by using an OpenLayers.Handler.Box tool in a custom
OpenLayers.Control, which then uses to the "done" callback of the draw
method to create (or recreate) an OpenLayers.Feature.Vector and populate
(or repopulate) a search form.
My immediate problem is that the persistent box is not in quite the same
location as the box the user just drew. I suspect this has something to
do with projections, but since I never explicitly set projections, I'm
not sure where the error sneaked in.
More generally, I'm not sure I'm taking the optimal route from the
bounds passed to the callback to the Vector feature. Currently, I do
the following:
1) Take the incoming OpenLayers.Bounds object,
2) Get an OpenLayers.Pixel from the the corners
3) Get the coordinates of each pixel using map.getLonLatFromPixel
4) Create a new OpenLayers.Bounds
5) Extend it to my new coordinates
6) Convert it to a geometry
7) Convert it to an OpenLayers.Feature.Vector
Then I take the coordinates from step 3) and populate a form with them,
which I then submit to my application server side.
The code for this is pasted here: http://pastebin.com/m300c24a5
Any pointers on how to do this more cleanly would be much appreciated.
Cheers,
Cliff
