[OpenLayers-Users] Add Point to Map
Alexandre Dube
adube at mapgears.com
Fri Nov 13 11:58:44 EST 2009
Christopher,
Jones, Christopher wrote:
> Hi
> Thanks for the tips! Its not quite what I was looking for unfortunately. I need the ability to add a point to be connected to a button I have on the web page rather than a specific OpenLayers Vector control.
How about this [1] ( still an OpenLayers approach, but outside the map... )?
Kind regards,
Alexandre
[1] http://openlayers.org/dev/examples/navtoolbar-outsidemap.html
> I have added the HTML element to hopefully help describe what I am trying to achieve.
> Thanks again
> Chris
> <%@ Page Language="VB" AutoEventWireup="false" CodeFile="Default.aspx.vb" Inherits="_Default" %>
> <!DOCTYPE html PUBLIC "-//W3C//DTD XHTML 1.0 Transitional//EN" "http://www.w3.org/TR/xhtml1/DTD/xhtml1-transitional.dtd">
> <html xmlns="http://www.w3.org/1999/xhtml">
> <head>
> <title>OpenLayers </title>
> <script src="http://maps.google.com/maps?file=api&v=2&key=ABQIAAAA-G5pfbkze92iVXWIhk7eJxRqZzHA8hAfFngd-nr1bRnZnyrphBR_DAMWurr6RFvtr6noMigi_EMbsw"type="text/javascript"></script>
> <script src="http://openlayers.org/api/OpenLayers.js" type="text/javascript"></script>
> <script src="JScript.js" type="text/javascript"></script>
> <style type="text/css">
> #Button1
> width: 83px;
> #Button2
> width: 81px;
> margin-left: 9px;
> #Button3
> width: 80px;
> margin-left: 9px;
> #Button4
> width: 82px;
> height: 21px;
> #Button5
> width: 82px;
> margin-left: 710px;
> margin-top: 0px;
> margin-bottom: 0px;
> </style>
> <script language="javascript" type="text/javascript">
> // <!CDATA[
> </script>
> </head>
> <body onload="initialiseMap()" bgcolor="#6699ff">
> <p>
> <input id="Button1" type="button" onclick=" singleClickButton ()" value="Single Click" />
> </p>
> <div style="height: 563px; width: 1063px; margin-top: 0px;" id="map">
> </div>
> </body>
> </html>
> -----Original Message-----
> From: users-bounces at openlayers.org [mailto:users-bounces at openlayers.org] On Behalf Of Alexandre Dube
> Sent: 13 November 2009 14:04
> To: Jones, Christopher
> Cc: users at openlayers.org
> Subject: Re: [OpenLayers-Users] Add Point to Map
> Christopher,
> Look at the following example [1]. It should helps you a lot. (click
> on the small pencil to add a point).
> See also this article [2] about spherical mercator.
> Kind regards,
> Alexandre
> [1] http://openlayers.org/dev/examples/spherical-mercator.html
> [2] http://docs.openlayers.org/library/spherical_mercator.html
>> Hi all,
>> Im fairly new to OpenLayers and javascript for that matter as well.
>> Having looked extensively through all the various examples and forums
>> and blogs, and one or 2 tutorials, I am still struggling to add a
>> point to a map (or a vector layer)! All I want, is to click on a map
>> and adda a point. Heres my code, please feel free to point all the
>> errors you want!
>> Thanks in advance!
>> Chris
>> (Sorry if this has been sent twice)
>> var myStyles = new OpenLayers.StyleMap({
>> "default": new OpenLayers.Style({
>> fillColor: "#ffcc66",
>> strokeColor: "#ff9933",
>> strokeWidth: 10
>> function initialiseMap(){
>> map = new OpenLayers.Map('map');
>> map.addControl(new OpenLayers.Control.LayerSwitcher());
>> var gphy = new OpenLayers.Layer.Google(
>> "Google Physical",
>> { type: G_PHYSICAL_MAP }
>> var gmap = new OpenLayers.Layer.Google(
>> "Google Streets",
>> {numZoomLevels: 20 }
>> var ghyb = new OpenLayers.Layer.Google(
>> "Google Hybrid",
>> { type: G_HYBRID_MAP, numZoomLevels: 20 }
>> var gsat = new OpenLayers.Layer.Google(
>> "Google Satellite",
>> { type: G_SATELLITE_MAP, numZoomLevels: 20 }
>> map.addLayers([gphy, gmap, ghyb, gsat]);
>> map.setCenter(new OpenLayers.LonLat(-74.0094,
>> 40.7048), 5);
>> map.addControl(new OpenLayers.Control.PanZoomBar());
>> map.addControl(new OpenLayers.Control.MousePosition());
>> function singleClickButton() {
>> document.getElementById("map").childNodes[0].style.cursor =
>> "crosshair";
>> map.events.register('click', '', singleClickEvent);
>> function singleClickEvent (e) {
>> var lonlat = map.getLonLatFromViewPortPx(e.xy);
>> var lon = lonlat.lon
>> var lat = lonlat.lat
>> var pointLayer = new OpenLayers.Layer.Vector('Points', { styleMap:
>> myStyles });
>> map.addLayers([pointLayer]);
>> var bPoint = new OpenLayers.Geometry.Point(lon , lat)
>> newpoint = new OpenLayers.Feature.Vector(bPoint);
>> pointLayer.addFeatures(newpoint);
>> IMPORTANT - This email and the information that it contains may be
>> confidential, legally privileged and protected by law. Access by the
>> intended recipient only is authorised. Any liability (in negligence or
>> otherwise) arising from any third party acting, or refraining from
>> acting, on any information contained in this email is hereby excluded.
>> If you are not the intended recipient, please notify
>> AmlinCommunications at amlin.co.uk immediately then delete it and do not
>> disclose the contents to any other person, use it for any purpose or
>> store or copy the information in any medium.
>> Copyright in this email and attachments created by us belong to Amlin
>> plc and/or one or more of its subsidiaries (Amlin Group). The author
>> also asserts the right to be identified as such and object to any misuse.
>> The Amlin Group prohibits and takes steps to prevent its email systems
>> from being used to view, store or transmit offensive, obscene or
>> discriminatory material. If this message contains inappropriate
>> material please report it immediately to AmlinCommunications at amlin.co.uk.
>> The Amlin Group records, monitors and may inspect messages that use
>> its telecoms systems in order to protect its information, interests
>> and reputation. Any message sent by you to or within the Amlin Group
>> may therefore be viewed and may be acted upon.
>> Of the companies within the Amlin Group, Amlin Underwriting Limited,
>> Amlin Underwriting Services Limited, Amlin UK Limited and Amlin Plus
>> Limited are authorised and regulated by the Financial Services Authority.
>> This email has been sent by a member of staff of one or more of the
>> following Amlin Group companies:
>> Amlin plc. Registered in England and Wales no. 2854310
>> Amlin Underwriting Limited. Registered in England and Wales no. 2323018
>> Amlin Underwriting Services Limited. Registered in England and Wales
>> no. 422615
>> Amlin UK Limited. Registered in England and Wales no. 2739220
>> Amlin Plus Limited. Registered in England and Wales no. 4729659
>> Registered Offices: St Helen's, 1 Undershaft, London EC3A 8ND, United
>> Kingdom
>> Amlin plc switchboard: 020 7746 1000
>> Web Site: http://www.amlin.com
>> Users mailing list
>> Users at openlayers.org
>> http://openlayers.org/mailman/listinfo/users
Alexandre Dubé
Mapgears
www.mapgears.com
