[OpenLayers-Users] Trying to draw a box on a map,
and get the coordinates back.
Scott Lewis
scott.lewis at nsidc.org
Fri Nov 13 13:56:10 EST 2009
Ah, sorry about that, I misunderstood the problem you were having!
J. Cliff Dyer wrote:
> Thanks. That's definitely a cleaner setup, but it didn't really solve
> the problem I was having. Before the box would look like it was being
> drawn properly, but then the persistent copy would be vertically offset.
> Now it's offset from the time I start drawing. Which is an improvement,
> because at least it will be easier for users to draw the box they want.
> Here's a screenshot to show what I mean:
> http://imgur.com/5cJ4H
> The Box was drawn exactly from Cape Fear to Cape Hatteras, marked with
> little black dots on the screenshot. However, the box itself starts
> drawing a bit above the location of the cursor. It seems the further I
> get from the top of the display, the further displaced the box is. It
> is impossible to get closer than ~2cm from the bottom of the map. There
> also seems to be a very slight horizontal displacement.
> Any thoughts on what might cause this displacement? At this point, no
> transformation is being done--at least not in any of my code.
> Cheers,
> Cliff
> On Fri, 2009-11-13 at 09:58 -0700, Scott Lewis wrote:
>> I did something like this using one of the examples on the OpenLayers
>> site, modified slightly. Here's what I used:
>> boxControl = new OpenLayers.Control();
>> OpenLayers.Util.extend(boxControl, {
>> draw: function() {
>> this.box = new OpenLayers.Handler.RegularPolygon(boxControl,
>> {"done": this.notice}, {sides:4, irregular:true, persist:true});
>> this.box.activate();
>> notice: function(geom) {
>> // whatever you want it to do after the box has been drawn
>> // then add the boxControl to the map
>> This works pretty nicely. Note that "geom" will be in the same
>> projection as the map, so if you want the output to be in another
>> projection (like a latitude/longitude display) you will have to go
>> through the geometry and transform the points. Also, you may have to go
>> through the geometry to determine which point is which (it doesn't
>> always start with the upper-left corner, and it's not always clockwise
>> or counter-clockwise). If interested, I can post some of the functions
>> I do for that.
>> I hope this helps,
>> Scott Lewis
>> NSIDC
>>> I'm trying to draw a box on a map, have it persist until another box
>>> gets drawn, and submit the coordinates of the box to a form. I'm doing
>>> this to allow the user to search for objects within a given area.
>>> I'm doing this by using an OpenLayers.Handler.Box tool in a custom
>>> OpenLayers.Control, which then uses to the "done" callback of the draw
>>> method to create (or recreate) an OpenLayers.Feature.Vector and populate
>>> (or repopulate) a search form.
>>> My immediate problem is that the persistent box is not in quite the same
>>> location as the box the user just drew. I suspect this has something to
>>> do with projections, but since I never explicitly set projections, I'm
>>> not sure where the error sneaked in.
>>> More generally, I'm not sure I'm taking the optimal route from the
>>> bounds passed to the callback to the Vector feature. Currently, I do
>>> the following:
>>> 1) Take the incoming OpenLayers.Bounds object,
>>> 2) Get an OpenLayers.Pixel from the the corners
>>> 3) Get the coordinates of each pixel using map.getLonLatFromPixel
>>> 4) Create a new OpenLayers.Bounds
>>> 5) Extend it to my new coordinates
>>> 6) Convert it to a geometry
>>> 7) Convert it to an OpenLayers.Feature.Vector
>>> Then I take the coordinates from step 3) and populate a form with them,
>>> which I then submit to my application server side.
>>> The code for this is pasted here: http://pastebin.com/m300c24a5
>>> Any pointers on how to do this more cleanly would be much appreciated.
>>> Cheers,
>>> Cliff
>>> Users mailing list
>>> Users at openlayers.org
>>> http://openlayers.org/mailman/listinfo/users
> Users mailing list
