[OpenLayers-Users] Load something like a "custom map"...
Pedro Baracho pedropbaracho at gmail.com
Mon Nov 16 09:20:03 EST 2009
Well you could use ogc filter to split them in 4 groups.
You could split them manually and load 4 different layers from 4 different
files for example.
And there is also something called Strategy on OL's Vector Layers, that is
an automatic way to crop/reduce the amount of data you are showing.
I can't say what is the best way, because I don't know how your points are
stored.
You don't need a map server, if you are splitting them manually or using
"Strategy" parameter. If you intend to use OGC Filter you will probably need
a OGC-Compliant map server, like Geoserver, for example.
Hope it helps,
Pedro.
2009/11/16 Quim Rifà <rifins at gmail.com>
> Hi,
> I have about 2000 points in a map, distributed in 4 categories (about 500
> points per category). If I try to add all the points at a time, it takes a
> lot of time to load all the points, and I would like to know if it is
> possible to create four "layers" (I don't know if the word layer fits to
> what I'm saying..) each one containing the points of a category, and then
> load the "layers". This would make the loading much faster.
> I need also that all the points can have their own events, like the click
> on a marker.
> Which is the best way to fit what I'm saying? I need a map server or there
> is any way to make this without creating a custom map with points?
> Thanks a lot!
> Users mailing list
> Users at openlayers.org
> http://openlayers.org/mailman/listinfo/users
URL: http://lists.osgeo.org/pipermail/openlayers-users/attachments/20091116/54a6c3bf/attachment.html
