[OpenLayers-Users] OpenLayers.Control.SelectFeature and
shift-click in Firefox
Richard Eichhorn
r.eichhorn at netbi.com.au
Mon Nov 16 22:09:37 EST 2009
Hi Pedro,
Thanks for the examples, but I was looking for an example where a handler is
defined within the selectFeature control. I want the default behavior for a
click and shiftClick, I just want to stop the event propagating to the
browser.
I have a feeling this could be a bug, as I had a look at the selectFeature
in Firebug, and the control contains a feature handler, and the stopClick
property is set to true. So it should stop the click reaching the browser.
On the <a> tag issue, there is no <a> tag, the images are rendered using a
styleMap and the externalGraphic property. Openlayers uses SVG to render
the image on the map -
<image id="OpenLayers.Geometry.Point_409" cx="475.49951501144096"
cy="368.1250306600705" r="1" title="Park Road - 6 [BT000928]"
preserveAspectRatio="none" x="463" y="353" width="24" height="24"
href="/spatial/iface/images/markerBlue.png" style="opacity: 1;"
fill="undefined" fill-opacity="1" stroke="none"/>
It is just default FF behavior.
In the end I have given up using multipleKey: "shiftKey" in the control,
and have settled for using toggle: true instead.
Thanks for the help.
Cheers,
Richard.
2009/11/16 Pedro Baracho <pedropbaracho at gmail.com>
> I have seen two examples of handlers to Click event:
> http://openlayers.org/dev/examples/click.html
> http://openlayers.org/dev/examples/click-handler.html
> I think you will have to create a handler to Keyboard events also, so you
> can capture the Shift+Key. In fact, I think you will only need that. Try
> adding
> to your SelectFeature control, so you override the shift+click behaviour of
> Firefox.
> Just a question: FF opens another window when you shift+click a link, i.e.
> <a> tag. Why is the <a> tag there on your externalGraphic in the first
> place??
> On Thu, Nov 12, 2009 at 11:10 PM, Richard Eichhorn <
> r.eichhorn at netbi.com.au> wrote:
>> Thanks for that. I did come across that, but I couldn't figure out how to
>> use it in the context of OpenLayers.Control.SelectFeature.
>> There is a handlers property but I can't figure out how to use it.
>> Has anyone got an example of creating an OpenLayers.Control.SelectFeature
>> with a handlers property defined?
>> Cheers,
>> Richard.
>> 2009/11/13 Pedro Baracho <pedropbaracho at gmail.com>
>> I am not sure if that helps, but there is a function stop on Event class
>>> for stopping event propagation.
>>> http://dev.openlayers.org/docs/files/OpenLayers/Events-js.html#OpenLayers.Event.stop
>>> On Thu, Nov 12, 2009 at 5:47 AM, Richard Eichhorn <
>>>> I am using OpenLayers.Control.SelectFeature with features which are
>>>> represented using an externalGraphic. When I use do a shift-click to
>>>> multi-select features in Firefox, it opens up a new window with the icon of
>>>> the feature I just clicked on.
>>>> When writing non-openlayers javascript code I have just used
>>>> preventDefault in firefox to stop the events propagating.
>>>> How can I do it in Openlayers?
>>>> Cheers,
>>>> Richard
>>>> _______________________________________________
>>>> Users mailing list
>>>> Users at openlayers.org
>>>> http://openlayers.org/mailman/listinfo/users
URL: http://lists.osgeo.org/pipermail/openlayers-users/attachments/20091117/9d966ba4/attachment.html
