[OpenLayers-Users] GeoServer Proxy Extension OpenLayers
Andreas Hocevar ahocevar at opengeo.org
Tue Nov 17 07:13:50 EST 2009
stash wrote:
> thanks for the answer. When I open my html file the browser opens it as a
> file.
> Is there any possibility how to solve the problem when i open it as a file?
No. OpenLayers is a *web* mapping library. I already told you to access
your page via http://localhost:8080/geoserver/www/<whatever>.
> (I develop a application in visual studio with openlayers. When I launch my
> app in visual studio the app will be opened as a html site
> (http://localhost:1234/Default.aspx). But there is the same problem with the
> http request.
Then you have to search for or write your own proxy in asp, or configure
the built-in http server of visual studio to use geoserver in a virtual
folder (e.g. http://localhost/1234/geoserver).
> Furthermore when I try to change the security settings to none the lowest
> level is "medium" (how can i change it to none?)
You should not do that.
> Hope you can help me.
You need to think about deployment of your application. This could be
the key to solving your problem. Your users won't run OpenLayers off
visual studio. You will  have an httpd (in your case probably IIS), and
you need to configure that to provide GeoServer at the same origin. IIRC
this is called "Virtual Folder" (or even Proxy) in IIS.
Regards,
Andreas.
Andreas Hocevar
OpenGeo - http://opengeo.org/
Expert service straight from the developers.
