[OpenLayers-Users] SLD on the fly
Brad Spencer
brad at cubewerx.com.au
Tue Nov 17 15:34:16 EST 2009
David,
You can manipulate the opacity of any layer within OL.
To change a layers opacity I just use the following method >>
layerObjectName.setOpacity(newOpacity);
Where newOpacity is a real number between 0 and 1 [0=transparent and
1=opaque therefore 0.5=half transparent etc].
Then all you need is some GUI tool to collect the number from the user.
Hope that helps.
Brad
From: users-bounces at openlayers.org [mailto:users-bounces at openlayers.org] On
Behalf Of David Alda Fernandez de Lezea
Sent: Wednesday, November 18, 2009 1:48 AM
To: users at openlayers.org
Subject: Re: [OpenLayers-Users] SLD on the fly
Hello,
I'm using MapServer WMS and want to apply some complex SLD to an OL WMS
layer. It seems that some features cannot be used in OL, for example putting
the text label in the centroid of the polygon or fill-opacity (I can't make
this work, even with mapserver). I've been looking to your web page and I've
realized that you have a slider bar which lets you set some transparency to
the style. How do you do that, if I can ask??
Thanks.
Un saludo,
David Alda Fernández de Lezea
Lurralde eta Biodibertsitate Saila / Dpto. de Territorio y Biodiversidad
IKT
Granja Modelo s/n · 01192 · Arkaute (Araba)
Tlfnos.: 945-00-32-95 Fax: 945-00.32.90
email: dalda at ikt.es web: www.ikt.es
<http://www.ikt.es/>
_____
De: users-bounces at openlayers.org [mailto:users-bounces at openlayers.org] En
nombre de Brad Spencer
Enviado el: lunes, 16 de noviembre de 2009 22:24
Para: 'Pedro Baracho'; 'Ian Turton'
CC: 'OpenLayers Users'
Asunto: Re: [OpenLayers-Users] SLD on the fly
Pedro,
I use CubeWerx WMS. This allows you to apply SLDs externally with no effect
on STYLES but you can also undertake a PutStyles if you have that access
privilege which will add/update the STYLE.
I build a library of SLDs if I want to keep them as permanent filters which
is important in my case as I am producing an infinite number of thematic
maps (DemographicDrapes) from Census statistics.
Have a look at http://demos.numaps.com.au/demographicdrapes.html
I have built a complex Style Builder application that allows the user to
pretty much change all aspects of a SLD and Save or SaveAs.
Cheers, Brad
Behalf Of Pedro Baracho
Sent: Tuesday, November 17, 2009 7:36 AM
To: Ian Turton
Cc: OpenLayers Users
Wow, I am impressed! What a cool map that is being displayed on my screen!
hehe :)
Thanks for the reply.
Guess I am set in solution 2.
Just another question. I don't see SLD BODY on WMS Spec, but I see it on SLD
profile for WMS. And it also states:
"GetMap is defined in WMS 1.3. The SLD profile for WMS defines additional
parameters allowing clients to request layers to be portrayed according to
some specified style."
Do you know any map server that doesn't support SLD profile for WMS, but
supports WMS? I am just curious about it, because imho it doesn't make sense
splitting SLD profile for WMS from WMS spec.
On Mon, Nov 16, 2009 at 5:54 PM, Ian Turton <ijturton at gmail.com> wrote:
On Mon, Nov 16, 2009 at 2:29 PM, Pedro Baracho <pedropbaracho at gmail.com>
wrote:
> I need to change SLD on the fly to create some thematic maps. I would also
> appreciate if compatibility with OGC's WFS was mantained. Have you guys
done
> this before? I could use some suggestions... :P
> I have done some searching and came up with a couple of solutions.
> 1- GeoServer GeoExt Styler Plugin.
> I don't know if it is a good solution, because as far as I know, it
changes
> the style of the layer for all the users. I would need to replicate styles
> on the server for each user and each layer. And also this requires the
> server to be Geoserver, and breaks OGC compatibility.
You are right that will change it for everyone
> 2- WMS 1.3 and SLD
> MapServer implements WMS 1.3 and accepts a SLD description in the request.
> GeoServer doesn't.
> Nothing against MapServer, but my current development environment is set
> with GeoServer..
Try
http://localhost:8080/geoserver/wms?bbox=-130,24,-66,50&Format=image/png&req
uest=GetMap&width=550&height=250&srs=EPSG:4326&SLD_BODY=%3CStyledLayerDescri
ptor%20version%3D%221.0.0%22%3E%3CUserLayer%3E%3CName%3Etopp:states%3C/Name%
3E%3CUserStyle%3E%3CName%3EUserSelection%3C/Name%3E%3CFeatureTypeStyle%3E%3C
Rule%3E%3CFilter%20xmlns:gml%3D%22http://www.opengis.net/gml%22%3E%3CPropert
yIsEqualTo%3E%3CPropertyName%3ESTATE_NAME%3C/PropertyName%3E%3CLiteral%3EIll
inois%3C/Literal%3E%3C/PropertyIsEqualTo%3E%3C/Filter%3E%3CPolygonSymbolizer
%3E%3CFill%3E%3CCssParameter%20name%3D%22fill%22%3E%23FF0000%3C/CssParameter
%3E%3C/Fill%3E%3C/PolygonSymbolizer%3E%3C/Rule%3E%3CRule%3E%3CLineSymbolizer
%3E%3CStroke/%3E%3C/LineSymbolizer%3E%3C/Rule%3E%3C/FeatureTypeStyle%3E%3C/U
serStyle%3E%3C/UserLayer%3E%3C/StyledLayerDescriptor%3E
(from the demo requests page in geoserver 1.7.5) - works for all WMS
versions.
> 3- WFS and treat SLD exhibition on the client
> This is a double edged solution. The good thing about WFS is that I have
> many more possibilities of control over the map. I can use SelectFeature
> control, instead of hacking some code to implement it over WMS. But it
also
> gives me many other options I don't need such as the vector data. I only
> need the images.
Not sure I understand your plan here but sounds like overkill - and
may kill off the browser if you have too much data.
Ian
Ian Turton
Sent from Houserville, Pennsylvania, United States
URL: http://lists.osgeo.org/pipermail/openlayers-users/attachments/20091118/02e26f68/attachment.html
