[OpenLayers-Users] Image flickering in Firefox when changing
the URL of an image layer
Pedro Baracho
pedropbaracho at gmail.com
Wed Nov 18 08:59:16 EST 2009
I am not sure if I made myself clear...
I could reproduce the flickering on the other computer.
On Wed, Nov 18, 2009 at 11:58 AM, Pedro Baracho <pedropbaracho at gmail.com>wrote:
> Mozilla/5.0 (Windows; U; Windows NT 5.1; pt-BR; rv:1.9.1.5) Gecko/20091102
> Firefox/3.5.5 (.NET CLR 3.5.30729)
> I don't see the flickering at all.
> I used FF on Safe-mode too, without any complements loaded.
> I could reproduce it on another computer with a different version of FF,
> and same version of .NET
> Mozilla/5.0 (Windows; U; Windows NT 5.1; pt-BR; rv:1.9.0.15)
> Gecko/2009101601 Firefox/3.0.15 (.NET CLR 3.5.30729)
> Also, I used to have IE Tab addon on Firefox (which replaces Gecko for IE
> rendering engine). I am just pointing this out, because once I was
> developing a web application and had to parse XML, and my code worked on my
> version of firefox and didn't work on this other computer. At that time, I
> was using a node attribute called "wholeText" and had to change it to "data"
> to keep compatibility.
> On Wed, Nov 18, 2009 at 11:42 AM, Bart van den Eijnden <bartvde at osgis.nl>wrote:
>> I can reproduce it in both Firefox 3.5.5 and Safari on Mac.
>> Best regards,
>> Bart
>> On Nov 18, 2009, at 2:38 PM, Marc Jansen wrote:
>> > Hi Pedro,
>> > Thanks for your input... but it seems odd: in my FF (Mozilla/5.0 (X11;
>> > U; Linux i686; de; rv:1.9.1.5) Gecko/20091109 Ubuntu/9.10 (karmic)
>> > Firefox/3.5.5) the upper OL-client is still flickering. Maybe some
>> > setting in Firefox I changed? Or a plugin?
>> > I am really puzzled.
>> > Can someone else reproduce the flickering?
>> > Regards,
>> > Marc
>> > Pedro Baracho wrote:
>> >> For the record, I am currently using FF 3.5.5, Gecko/20091102 on
>> >> Windows and I don't see any flickering in the link you posted.
>> >> On Wed, Nov 18, 2009 at 11:10 AM, Marc Jansen <jansen at terrestris.de
>> >> <mailto:jansen at terrestris.de>> wrote:
>> >> Hi list,
>> >> when the URL of an imagelayer is changed via the APIMethod setUrl,
>> the
>> >> image is flickering regardless of the browser cache or the
>> transition
>> >> effect. This behaviour can be seen e.g. here:
>> >> http://www.webmapcenter.de/wetterradar/animation.html
>> >> In that demo the URL of the imagelayer is changed every 500 ms and
>> the
>> >> flickering should be easy to spot (at least if you wait for roughly
>> 20
>> >> seconds). Firebugs Net-tab shows that the images are being requested
>> >> over and over.
>> >> The flickering is only noticeable in Firefox (3.5 Win and Linux);
>> >> Opera
>> >> 10 and IE 8 work like a charm (they cache the varying images). The
>> >> changing of the src of a pure <img> with JavaScript does not show
>> the
>> >> flickering (as can be seen in the above link, too). I don't have
>> >> results
>> >> for other browsers.
>> >> Can anybody help me identify the root of this flickering? I am
>> unsure
>> >> whether this Firefox bugreport is maybe relevant to this issue:
>> >> https://bugzilla.mozilla.org/show_bug.cgi?id=492052. I doubt that
>> >> it is
>> >> related to apache settings (Caching- or Expires-Headers) as the
>> >> pure JS
>> >> solution isn't flickering at all.
>> >> Any help or advice on this issue would be great!
>> >> Regards,
>> >> Marc
>> >> BTW.: If someone shows me a better alternative to build an
>> >> animation of
>> >> different Imagelayers, I would be happy as well :-)
>> >> _______________________________________________
>> >> Users mailing list
>> >> Users at openlayers.org <mailto:Users at openlayers.org>
>> >> http://openlayers.org/mailman/listinfo/users
>> > Users mailing list
URL: http://lists.osgeo.org/pipermail/openlayers-users/attachments/20091118/5604e15f/attachment.html
