[OpenLayers-Users] OpenLayer + Google Maps API key
Czarek Tomaszewski
cezarto at interia.pl
Thu Nov 19 04:57:46 EST 2009
I’ve created application based on GWT-OpenLayer. It works OK. Application enables client to change that key in configuration form but I’ve noticed that when I put incorrect key, popup window informs me:
“This web site needs a different Google Maps API key …” and it is OK,
but after all, map is opening. I think it should not. I checked this also using simple example from http://workshops.opengeo.org/stack-intro/openlayers.html and problem is the same.
Does anyone know how to solve the problem?
Thanks in advance,
Czarek
Audi kilka tysiecy zlotych taniej? Przebieraj wsrod tysiecy ogloszen!
Kliknij >>> http://link.interia.pl/f2424
