[OpenLayers-Users] GetFeatureInfo... Access denied..
stash
steffen.schwarz85 at googlemail.com
Thu Nov 19 11:36:44 EST 2009
Quim Rifà wrote:
> Hi list,
> I know that tere are so many comments about that, but no one is solving my
> problem..
> I have geoserver serving a WMS vector layer that has some features... I
> have
> the geoserver running in localhost:8080, and the application that I'm
> testing, is running in localhost:3015.. And I suppose that due de
> different
> ports, when I try to do a GetFeatureInfo (clicking anywhere on the map),
> it
> says "access denied".. In the XMLHttpRequest.open(...).
> I've added the proxy following the instructions found in "
> http://geoserver.org/display/GEOS/GeoServer+Proxy+Extension".. But it
> still
> says that there is no access..
> Then I tryied to initialize the proxy host, in the "function Init()",
> writing "OpenLayers.ProxyHost = "/geoserver/rest/proxy?url=";" And now
> what
> it says, is that it can't find the resource, and suggest to verify the url
> "/geoserver/rest/proxy"
> What is happening with that? Any idea?
> Thanks!!
> Users mailing list
> Users at openlayers.org
> http://openlayers.org/mailman/listinfo/users
Hello,
I had the same problem and I know that this can be really frustrating. But
you can try the following things.
Thereby your html site and geoserver are running on the same pc (localhost)
you don't need a proxyhost. Set it in comments in your html.
Try it out with different browsers. Firefox always blocked my request and
with Internet Explorer it worked.
Maybe this helps.
Regards
stash
View this message in context: http://n2.nabble.com/GetFeatureInfo-Access-denied-tp4032182p4032903.html
