[OpenLayers-Users] mapExtents for Layer vs mapExtents for Map
srweal
srweal at gmail.com
Fri Nov 20 01:28:33 EST 2009
Hi there,
I'm a new OpenLayers user and am struggling with the use of the mapExtent
setting. I have a WMS that renders imagery for me, which is being accessed
through a TileCache. The imagery only covers part of my entire map, so I
want to make sure OpenLayers is not requesting image tiles for areas beyond
the extent of the layer.
However, when I set a mapExtent on my WMS layer to something like
(135,-45,180,0), it is still displaying 'pink tiles' over top of the base
layer of the map (which has mapExtent -something like 180,-90,180,90). This
seems wrong, as the WMS layer may be set up to only return tiles inside the
BBOX (135,-45,180,0). Am I missing something here with the way these
options are supposed to work? Please explain.
The error response for the 'pink tiles' is "Lower left corner (90,-45) is
outside layer bounds [135,-45,180,0]. To remove this condition, set
extent_type=loose in your configuration."
If I set the TileCache to extent_type=loose, all I get is blank
(transparent) tiles rendered everywhere which seems like a waste of server
resources to me. I thought that by setting the mapExtent on the layer, I
would avoid OpenLayers requesting tiles beyond those extents. Can someone
please explain how this works?
Thanks. Otherwise, everything is working great for me. The combination of
TileCache, mod_python, OpenLayers is awesome. Well done.
Steve
View this message in context: http://n2.nabble.com/mapExtents-for-Layer-vs-mapExtents-for-Map-tp4036288p4036288.html
