[OpenLayers-Users] GetFeatureInfo... Access denied..
JuKiM
rifins at gmail.com
Fri Nov 20 06:35:04 EST 2009
Ok.. Then... Any hint to setup the IIS Proxy?
Thanks!
2009/11/19 Christopher Schmidt <crschmidt at metacarta.com>
> On Thu, Nov 19, 2009 at 06:03:23PM +0100, JuKiM wrote:
> > Hi,
> > I've been testing in IE.. If I create a 'test.html' file in a folder
> under
> > IIS, I get an error of denied access/resource not available.. But if I
> copy
> > that file in the www folder of geoserver, then everything works ok.. This
> is
> > quite logical, because IIS is running on port 80, and geoserver in 8080
> > (They are different hosts)...
> > Then when I declare the proxy, the IIS's test.html, the response i get is
> > empty..
> Your *IIS* needs the proxy. GeoServer has one built in, but it won't help
> you in the slightest if your HTML page isn't hosted on GeoServer. So
> either host your page on geoserver's webserver, or get a proxy into
> whatever webserver you do need.
> -- Chris
URL: http://lists.osgeo.org/pipermail/openlayers-users/attachments/20091120/6e43b90b/attachment.html
