[OpenLayers-Users] Problem with WMSGetFeatureInfo erroring out
Stephen Woodbridge
woodbri at swoodbridge.com
Fri Nov 20 17:11:14 EST 2009
OK, part of the problem is solved I added to the matadata:
'wms_feature_info_mime_type' "text/html"
which fix the error, but now I get back what looks like image map of the
features which is not what I was expecting.
I currently have TEMPLATE "dummy" in my layers, do I need to create a
real template for each layer? I thought that this was supposed to return
GML with something like COL_NAME = col_value for each of the columns.
-Steve
Stephen Woodbridge wrote:
> Hi all,
> I'm trying to WMSGetFeatureInfo but have the following problem when
> using it with mapserver:
> http://example.com/cgi-bin/mapserv?map=/maps/test-900913-wms.map&&service=WMS&version=1.1.0&request=GetFeatureInfo&layers=OneMileETJ%2CLakes%2CParcels%2CRailroad%2CFMRoads%2CServiceRoads%2CStreets%2CHighways%2CInterstate%2CVoting_Precincts%2CCityLimits%2CZoning,FMRoads%2CServiceRoads%2CStreets%2CHighways%2CInterstate,Voting_Precincts,Zoning,Parcels&query_layers=OneMileETJ%2CLakes%2CParcels%2CRailroad%2CFMRoads%2CServiceRoads%2CStreets%2CHighways%2CInterstate%2CVoting_Precincts%2CCityLimits%2CZoning,FMRoads%2CServiceRoads%2CStreets%2CHighways%2CInterstate,Voting_Precincts,Zoning,Parcels&styles=%2C%2C%2C%2C%2C%2C%2C%2C%2C%2C%2C,%2C%2C%2C%2C,,,&bbox=-10739792.365943%2C3773437.912618%2C-10739165.343461%2C3774064.9351&srs=EPSG%3A900913&feature_count=10&x=217&y=267&height=525&width=525&info_format=text%2Fhtml
> And I get the following:
> <?xml version='1.0' encoding="ISO-8859-1" standalone="no" ?>
> <!DOCTYPE ServiceExceptionReport SYSTEM
> "http://schemas.opengis.net/wms/1.1.0/exception_1_1_0.dtd">
> <ServiceExceptionReport version="1.1.0">
> <ServiceException>
> msWMSFeatureInfo(): WMS server error. Unsupported INFO_FORMAT value
> (text/html).
> </ServiceException>
> </ServiceExceptionReport>
> If I remove the 'info_format=text%2Fhtml' part from the url I get back:
> GetFeatureInfo results:
> Layer 'OneMileETJ'
> Feature 0:
> Layer 'Parcels'
> Feature 1:
> Layer 'Voting_Precincts'
> Feature 0:
> Layer 'Zoning'
> Feature 1:
> Which does not seem all that useful, but this is my first attempt, and
> I'm probably missing something basic.
> A typical mapfile LAYER entry looks like:
> LAYER
> NAME "Parcels"
> METADATA
> wms_title "Parcels"
> END
> TRANSPARENCY ALPHA
> STATUS ON
> CONNECTIONTYPE postgis
> CONNECTION "user=****** dbname=mydb_test host=localhost"
> DATA "the_geom from (select * from parcels) as foo using
> SRID=900913 using unique gid"
> TYPE POLYGON
> LABELITEM "parcel_id"
> MAXSCALEDENOM 4000
> TEMPLATE "dummy"
> DUMP TRUE
> PROJECTION
> "init=epsg:900913"
> END
> CLASS
> STYLE
> COLOR -1 -1 -1
> WIDTH 2
> OUTLINECOLOR 255 0 255
> END
> LABEL
> TYPE TRUETYPE
> FONT "arial"
> SIZE 7
> COLOR "#000000"
> PARTIALS FALSE
> END
> END
> END
> Any help would be appreciated.
> -Steve W
> Users mailing list
> Users at openlayers.org
> http://openlayers.org/mailman/listinfo/users
