[OpenLayers-Users] Vector disappears when zooming in (sometimes)
Andreas Hocevar
ahocevar at opengeo.org
Sun Nov 22 15:13:31 EST 2009
Tommy74 wrote:
> What does "renderer runs out of coordinate space" really mean? Is
> there a limitation in OpenLayers/VML or is this a common
> GIS-"feature"? Can it be fixed or is it possible to do a
> simple workaround?
The problem is that at high resolutions, when you have points that are
too far apart, your drawing coordinates get larger than VML can handle.
> The vector data is not a static file, but is created as GeoJSON on the
> server in my real application, but that's a custom geojson generator,
> not a WFS or FeatureServer.
So maybe you could give your custom geojson generator a bbox filter?
> Unfortunately there is no time to change the type of datasource at the
> moment. The goal is to serve the data from WMS instead (in a later
> version), since its a lot of data. The example that I linked to is a
> reduced geometry.
Yeah, WMS would be a good solution in that case.
Regards,
Andreas.
Andreas Hocevar
OpenGeo - http://opengeo.org/
Expert service straight from the developers.
