[OpenLayers-Users] mapExtents for Layer vs mapExtents for Map
Eric Lemoine
eric.lemoine at camptocamp.com
Mon Nov 23 01:33:35 EST 2009
On Friday, November 20, 2009, srweal <srweal at gmail.com> wrote:
> Hi there,
> I'm a new OpenLayers user and am struggling with the use of the mapExtent
> setting. I have a WMS that renders imagery for me, which is being accessed
> through a TileCache. The imagery only covers part of my entire map, so I
> want to make sure OpenLayers is not requesting image tiles for areas beyond
> the extent of the layer.
> However, when I set a mapExtent on my WMS layer to something like
> (135,-45,180,0), it is still displaying 'pink tiles' over top of the base
> layer of the map (which has mapExtent -something like 180,-90,180,90). This
> seems wrong, as the WMS layer may be set up to only return tiles inside the
> BBOX (135,-45,180,0). Am I missing something here with the way these
> options are supposed to work? Please explain.
OpenLayers uses the current base layer's maxExtent as the max extent
for the map. So your WMS layer must be a base layer for its maxExtent
to be taken into account. Also, make sure you use "maxExtent", and not
"mapExtent".
cheers,
Eric Lemoine
Camptocamp France SAS
Savoie Technolac, BP 352
73377 Le Bourget du Lac, Cedex
Tel : 00 33 4 79 44 44 96
Mail : eric.lemoine at camptocamp.com
http://www.camptocamp.com
