[OpenLayers-Users] Remove Features By Id
Ivan Grcic igrcic at gmail.com
Thu Nov 26 05:48:58 EST 2009
mylayer.removeFeatures(mylayer.getFeatureById(startpoint.id))
Andreas, I think that array param is not necessary, single feature
should also work
* APIMethod: removeFeatures line 581:
if (!(features instanceof Array)) {
            features = [features];
BTW features automatically get id, so  I wouldnt asign IDs manually.
Cheers
On Thu, Nov 26, 2009 at 8:40 AM, Andreas Hocevar <ahocevar at opengeo.org> wrote:
> Hi,
> Mehmet Sirin wrote:
>> I'm failing when trying to remove a feature selected by its ID:
>> var startpoint= new OpenLayers.Feature.Vector(point,null,start_style);
>> startpoint.id <http://startpoint.id>="hey";
>> mylayer.addFeatures([startpoint]);
>> var something=getFeatureById("hey"); //works
>> mylayer.removeFeatures(mylayer.features[something]);
> The removeFeatures method takes an array of features as argument:
> myLayer.removeFeatures([something]);
> Regards,
> Andreas.
>> Maybe  it's in general not possible choosing a feature by an
>> associative key ?
>> Then how solving this problem in another, elegant way ? (i have a
>> solution for my problem, but it's definitely not fine or elegant^^)
>> leaving you kind regards
>> mehmet sirin c.
>> Users mailing list
>> Users at openlayers.org
>> http://openlayers.org/mailman/listinfo/users
> Andreas Hocevar
> OpenGeo - http://opengeo.org/
> Expert service straight from the developers.
> Users mailing list
Ivan Grcic
