[OpenLayers-Users] WFS + Filter
Ivan Grcic igrcic at gmail.com
Thu Nov 26 06:37:44 EST 2009
Yes, but using it together with Fixed strategy doesnt work. Maybe
there is ticket allready opened for that, ill take a look.
Stash, can you try putting defaultFilter option inside protocol params?
On Thu, Nov 26, 2009 at 12:27 PM, Kris Geusebroek <kgeusebroek at xebia.com> wrote:
> Hi,
>  filter should into layer options!
> Something like this:
> function setRadiusFilter(ft) {
>        if (ft != null) {
>                var radiusFilter = new OpenLayers.Filter.Spatial(
>                                type: OpenLayers.Filter.Spatial.DWITHIN,
>                                distance: selectedRadius,
>                                value: ft.geometry,
>                                projection: myLayer.projection
>                var combinedFilter=new OpenLayers.Filter.Logical({
>                        type:OpenLayers.Filter.Logical.AND,
>                        filters:[filter,radiusFilter]
>                myLayer.filter = combinedFilter;
> Cheers Kris
> -----Original Message-----
> From: users-bounces at openlayers.org [mailto:users-bounces at openlayers.org]
> On Behalf Of Ivan Grcic
> Sent: Thursday, November 26, 2009 12:19 PM
> To: stash
> Cc: users at openlayers.org
> Subject: Re: [OpenLayers-Users] WFS + Filter
> Im going to check it out with my data now. I have to examine request
> and see if the filter is actually sent in the request.
> In the meanwhile, can you try with BBOX Strategy instead of Fixed
> strategy?( Put your filter in layer options)
> On Thu, Nov 26, 2009 at 12:08 PM, stash
> <steffen.schwarz85 at googlemail.com> wrote:
>> Ivan Grcic-2 wrote:
>>> Hi,
>>> I think filter should go inside protocol params.
>>> And try with maxFeatures instead of maxfeatures.
>>> Let me know if it worked
>>> Cheers
>> Hi,
>> thanks for the hint. First the good news. When I type maxFeatures
> instead of
>> maxfeatures it works. Thats fine. But the filter, which is much more
>> important for me, isn't working (even when I put the filter: my_filter
> param
>> inside the protocol params.)
>> Do you have any other idea?
>> Regards
>> stash
>> View this message in context:
> http://n2.nabble.com/WFS-Filter-tp4049517p4070602.html
>> Sent from the OpenLayers Users mailing list archive at Nabble.com.
>> Users mailing list
>> Users at openlayers.org
>> http://openlayers.org/mailman/listinfo/users
> Ivan Grcic
> Users mailing list
Ivan Grcic
