[OpenLayers-Users] Control.GetFeature
Andreas Hocevar
ahocevar at opengeo.org
Mon Nov 30 04:14:35 EST 2009
why are you forcing your format to JSON? And are you sure that your
geometryName is "GEOM", not "the_geom"? Try to omit the readFormat and
formatOptions properties.
Regards,
Andreas.
stash wrote:
> Ivan Grcic-2 wrote:
>> OpenLayers.Protocol.WFS.fromWMSLayer is just convinient method for
>> creating OpenLayers.Protocol.WFS from allready defined WMS layer. So
>> you can just define protocol as:
>> protocol: OpenLayers.Protocol.WFS({
>> readFormat: new OpenLayers.Format.GeoJSON(),
>> formatOptions: {
>> outputFormat: "JSON"
>> url: "http://localhost:8080/geoserver/wfs"
>> featureType: "ftName",
>> featurePrefix: 'prefix',
>> featureNS: "http://ns",
>> geometryName: 'geometry',
>> maxFeatures: 100
> Hello,
> thanks for your post. I tried this but it doesn't work. Here is my code.
> var control = new OpenLayers.Control.GetFeature({
> formatOptions: {
> url: "http://localhost:8080/geoserver/wfs",
> featureType: "MY_LAYER",
> featurePrefix: 'topp',
> featureNS: "http://www.openplans.org/topp",
> geometryName: 'GEOM',
> maxFeatures: 100,
> defaultFilter: my_filter
> control.events.register("featureselected", this, function(e) {
> select.addFeatures([e.feature]);
> map.addControl(control);
> control.activate();
> When I launch my app I get an error that feature.lenght is null or doesn't
> exist?
> Do I have to implement a map.events.register as I did it with my
> getfeatureinfo or is there something else wrong.
> Thanks for your help
> Regards
> stash
Andreas Hocevar
OpenGeo - http://opengeo.org/
Expert service straight from the developers.
