[OpenLayers-Users] Call layer
David Fawcett
david.fawcett at gmail.com
Fri Oct 2 10:06:38 EDT 2009
Marc is correct, this is definitely a question for the MapServer list.
The short answer is that if you want a layer to always be drawn, set
status to DEFAULT. With a status of ON, you still need to include the
layer name in the URL. (This quirk of MapServer confuses a lot of
people.)
David.
On Fri, Oct 2, 2009 at 4:31 AM, Marc Jansen <jansen at terrestris.de> wrote:
> Hi there,
> I would guess that this list is probably the wrong place to ask this
> question. I furthermore guess you are experiencing problems with UMN
> mapserver, right? Maybe their mailinglist [1] can help.
> Regards,
> Marc
> [1] http://lists.gis.umn.edu/mailman/listinfo/mapserver-users
> jbloc1878 at googlemail.com schrieb:
>> Hi,
>> I have my layer status set as ON however my layer does not display
>> when viewing my map via cgi-bin\mapserv.exe, Unless I call the layer
>> within the URL, is there another method to call the layer? (without
>> using status default)
>> Cheers for any help
>> Users mailing list
>> Users at openlayers.org
>> http://openlayers.org/mailman/listinfo/users
> Users mailing list
