[OpenLayers-Users] Result of expression 'map' [undefined] is
not an object.
Paul Spencer
pagameba at gmail.com
Sun Oct 4 18:36:12 EDT 2009
Also note that in IE (6 and 7, not sure about 8), if you have an
element with an id, any global variables (used without declaring with
a var) of the same name refers to the element, not what you assign to
it. So if you do this:
<html>
<head>
<script src="OpenLayers.js"></script>
<script>
map = new OpenLayers.Map( 'map' );
map.addLayer(new OpenLayers.Layer.Vector('vector');
</script>
</head>
<body>
<div id='map'></div>
</body>
</html>
you will get an error in IE (6 and 7 at least) with the line that
starts map.addLayer whereas if you change the previous line to:
var map = new OpenLayers.Map( 'map' );
you will not get an error.
Yeay IE
Cheers
Paul
On 2009-10-04, at 1:13 PM, Andreas Hocevar wrote:
> Also make sure that you don't have extra commas at the end of object
> definitions.
> Regards,
> Andreas.
> Stephen Woodbridge wrote:
>> Nicholas Efremov-Kendall wrote:
>>> Hi all,
>>> I'm getting the following error in what used to be functional
>>> code Result of expression 'map' [undefined] is not an object.
>>> It's breaking on the statement map.addLayer(cities). Here's the
>>> exerpted
>>> code that I've added around this. I can add a stripped down
>>> version of
>>> the rest, but it's bulky and I've only messed with the following
>>> bits.
>>> Any suggestions as to what's causing this error?
>>> var styleMap = new OpenLayers.StyleMap(
>>> {'default':OpenLayers.Util.applyDefaults(
>>> label: '${Name}',
>>> strokeWidth:1,
>>> strokeColor:"#CCCCCC",
>>> fillColor: "green",
>>> var cities = new OpenLayers.Layer.GML
>>> ("7th Century Cities", "data/cities.gml",
>>> styleMap: styleMap,
>>> projection: new OpenLayers.Projection("EPSG:4326"),
>>> format: OpenLayers.Format.GML,
>>> label: "${Name}",
>>> map.addLayer(cities);
>> Where is "var map" defined. It sounds like it is not in the visible
>> scope of the above code.
>> -Steve W
>> Users mailing list
>> Users at openlayers.org
>> http://openlayers.org/mailman/listinfo/users
> Andreas Hocevar
> OpenGeo - http://opengeo.org/
> Expert service straight from the developers.
> Users mailing list
