[OpenLayers-Users] Result of expression 'map' [undefined] is
not an object.
Stephen Woodbridge
woodbri at swoodbridge.com
Sun Oct 4 23:44:24 EDT 2009
Kishor,
I'm pretty sure that the trailing common is not portable across
browsers, as I'm sure I have had problems with that in the past. It is a
common model that I learned in Perl, but it is not supported by most
other languages. :(
-Steve
P Kishor wrote:
> On Sun, Oct 4, 2009 at 12:13 PM, Andreas Hocevar <ahocevar at opengeo.org> wrote:
>> Also make sure that you don't have extra commas at the end of object
>> definitions.
> if you mean, do like this
> var foo = { a: 'blah', b: 'blech' };
> and not like
> var foo = { a: 'blah', b: 'blech', };
> let me ask you, why not? Javascript doesn't mind, and it makes my
> programming a lot easier to let there be a comma at the end.
>> Regards,
>> Andreas.
>> Stephen Woodbridge wrote:
>>> Nicholas Efremov-Kendall wrote:
>>>> Hi all,
>>>> I'm getting the following error in what used to be functional
>>>> code Result of expression 'map' [undefined] is not an object.
>>>> It's breaking on the statement map.addLayer(cities). Here's the exerpted
>>>> code that I've added around this. I can add a stripped down version of
>>>> the rest, but it's bulky and I've only messed with the following bits.
>>>> Any suggestions as to what's causing this error?
>>>> var styleMap = new OpenLayers.StyleMap(
>>>> {'default':OpenLayers.Util.applyDefaults(
>>>> label: '${Name}',
>>>> strokeWidth:1,
>>>> strokeColor:"#CCCCCC",
>>>> fillColor: "green",
>>>> var cities = new OpenLayers.Layer.GML
>>>> ("7th Century Cities", "data/cities.gml",
>>>> styleMap: styleMap,
>>>> projection: new OpenLayers.Projection("EPSG:4326"),
>>>> format: OpenLayers.Format.GML,
>>>> label: "${Name}",
>>>> map.addLayer(cities);
>>> Where is "var map" defined. It sounds like it is not in the visible
>>> scope of the above code.
>>> -Steve W
>>> Users mailing list
>>> Users at openlayers.org
>>> http://openlayers.org/mailman/listinfo/users
>> Andreas Hocevar
>> OpenGeo - http://opengeo.org/
>> Expert service straight from the developers.
>> Users mailing list
