[OpenLayers-Users] Result of expression 'map' [undefined] is
not an object.
P Kishor
punk.kish at gmail.com
Mon Oct 5 01:09:18 EDT 2009
On Mon, Oct 5, 2009 at 12:02 AM, Roald de Wit <roald.dewit at lisasoft.com> wrote:
> Hi,
> On 05/10/09 14:53, P Kishor wrote:
>> On Sun, Oct 4, 2009 at 10:44 PM, Stephen Woodbridge
>> <woodbri at swoodbridge.com> wrote:
>>> Kishor,
>>> I'm pretty sure that the trailing common is not portable across browsers, as
>>> I'm sure I have had problems with that in the past. It is a common model
>>> that I learned in Perl, but it is not supported by most other languages. :(
>> Yup, I too picked up that good habit in Perl, and thoroughly enjoy
>> being lazy with it. That said, I am doing development right now and
>> testing in both Safari 4.x and Firefox 3.5x, and the trailing comma
>> seems to work fine. I don't have access to any version of IE (well,
>> not easily anyway) so I haven't really tested.
>> Can someone please confirm the browsers/versions in which the trailing
>> comma croaks?
> This is a confirmation: using a trailing comma in an object (curly
> brackets) is an easy way to bring IE6/7/8 to its knees and hard to debug
> without developer tools.
> Any other browser (that I know of) has no issues with it, only IE.
Many thanks Roald.
(eyes gleam at the prospect of being able to harass IE users)
> Regards,
> Roald
>>> -Steve
>>> P Kishor wrote:
>>>> On Sun, Oct 4, 2009 at 12:13 PM, Andreas Hocevar<ahocevar at opengeo.org>
>>>> wrote:
>>>>> Also make sure that you don't have extra commas at the end of object
>>>>> definitions.
>>>> if you mean, do like this
>>>> var foo = { a: 'blah', b: 'blech' };
>>>> and not like
>>>> var foo = { a: 'blah', b: 'blech', };
>>>> let me ask you, why not? Javascript doesn't mind, and it makes my
>>>> programming a lot easier to let there be a comma at the end.
>>>>> Regards,
>>>>> Andreas.
>>>>> Stephen Woodbridge wrote:
>>>>>> Nicholas Efremov-Kendall wrote:
>>>>>>> Hi all,
>>>>>>> I'm getting the following error in what used to be functional
>>>>>>> code Result of expression 'map' [undefined] is not an object.
>>>>>>> It's breaking on the statement map.addLayer(cities). Here's the
>>>>>>> exerpted
>>>>>>> code that I've added around this. I can add a stripped down version of
>>>>>>> the rest, but it's bulky and I've only messed with the following bits.
>>>>>>> Any suggestions as to what's causing this error?
>>>>>>> var styleMap = new OpenLayers.StyleMap(
>>>>>>> {'default':OpenLayers.Util.applyDefaults(
>>>>>>> label: '${Name}',
>>>>>>> strokeWidth:1,
>>>>>>> strokeColor:"#CCCCCC",
>>>>>>> fillColor: "green",
>>>>>>> var cities = new OpenLayers.Layer.GML
>>>>>>> ("7th Century Cities", "data/cities.gml",
>>>>>>> styleMap: styleMap,
>>>>>>> projection: new OpenLayers.Projection("EPSG:4326"),
>>>>>>> format: OpenLayers.Format.GML,
>>>>>>> label: "${Name}",
>>>>>>> map.addLayer(cities);
>>>>>> Where is "var map" defined. It sounds like it is not in the visible
>>>>>> scope of the above code.
>>>>>> -Steve W
>>>>>> _______________________________________________
>>>>>> Users mailing list
>>>>>> Users at openlayers.org
>>>>>> http://openlayers.org/mailman/listinfo/users
>>>>> Andreas Hocevar
>>>>> OpenGeo - http://opengeo.org/
>>>>> Expert service straight from the developers.
>>>>> Users mailing list
> Roald de Wit
> Software Engineer
> Commercial Support for Open Source GIS Software
> http://lisasoft.com/LISAsoft/SupportedProducts/
> The contents of this email are confidential and may be subject to legal or professional privilege and copyright. No representation is made that this email is free of viruses or other defects. If you have received this communication in error, you may not copy or distribute any part of it or otherwise disclose its contents to anyone. Please advise the sender of your incorrect receipt of this correspondence.
> Users mailing list
Puneet Kishor http://www.punkish.org
Carbon Model http://carbonmodel.org
Charter Member, Open Source Geospatial Foundation http://www.osgeo.org
Science Commons Fellow, http://sciencecommons.org/about/whoweare/kishor
Nelson Institute, UW-Madison http://www.nelson.wisc.edu
Assertions are politics; backing up assertions with evidence is science
Sent from Madison, WI, United States
