[OpenLayers-Users] Grouping Features into "one" feature using
Styles or other means
David Fawcett
david.fawcett at gmail.com
Tue Oct 6 10:57:32 EDT 2009
Good point Chris.
I wasn't thinking of clustering (a requirement Jon's...)
I guess that I was thinking that one could do some sort of data
thinning and provide those views at smaller scales. Either way, if
one thinned the data or applied a clustering algorithm, this would
likely be done as a pre-processing step to prepare some data sets to
build a WMS on.
In short, never mind...
Apologies for sending you down the wrong path.
David.
On Tue, Oct 6, 2009 at 9:40 AM, Christopher Schmidt
<crschmidt at metacarta.com> wrote:
> On Tue, Oct 06, 2009 at 09:22:47AM -0500, David Fawcett wrote:
>> Also, if you don't need the vector feature funcionality (and you are
>> using a server product capable of serving a WMS), you might think
>> about using a WMS layer and dealing with the scale-dependent rendering
>> on the server side.
> I'm not aware of any map rendering products that do clustering-style
> displays easily, though? Maybe this is an option in some of them
> that I'm not aware of?
> -- Chris
>> David.
>> On Tue, Oct 6, 2009 at 1:27 AM, Christopher Schmidt
>> > On Mon, Oct 05, 2009 at 04:07:27PM -0800, Jonathan Sawyer wrote:
>> >> Hi everyone,
>> >> I have a feature class of points that displays a breadcrumb trail of GPS
>> >> points for a target. When zoomed out to the full extent of the map,
>> >> OpenLayers renders 1000+ points in a tiny little area, thus reducing
>> >> performance of my application. Is there a way I can tell OpenLayers to
>> >> render just one point for a bunch of points within a given radius of the
>> >> point? For example, when zoomed out to the full extent, I would rather have
>> >> 1 to 3 points rendered rather than 1000+, but then be able to see every
>> >> point applicable when zoomed in.
>> > Clustering.
>> > http://openlayers.org/dev/examples/strategy-cluster.html
>> >> Thanks in advance for any help.
>> >> Jon
>> >> _______________________________________________
>> >> Users mailing list
>> >> Users at openlayers.org
>> >> http://openlayers.org/mailman/listinfo/users
>> > Users mailing list
>> Users mailing list
> Christopher Schmidt
> MetaCarta
